Lowering the 420SEL
420.SELect
Lowering the 420SEL
Post by 420.SELect » Wed 10 Jan, 2018 10:51 pm
Hi Guys,
I am looking into lowering my 420SEL and would appreciate some advice.
Firstly, Springs - Most of the posts I have read recommend, and have installed, H&R Sport Springs (the SLS option, as I believe my '88 420SEL has SLS) so I'm pretty confident that this choice is a no brainer. However, the number of nubs seems to be up to personal preference or enough for safe operation.
Next, Shocks - Should I upgrade the current shocks?
If so, should I go with Bilstien B4s or B8s, or even Koni's? Some posts say stick with the comforts and others recommend the B8's.
Lastly, hub-centric spacers - The posts I have read mention that wheel spacers - especially for the rear - make the look a bit more complete.
I don't think my front ones will need them but I think the rear, based on the comments of other who have done the same, could do with 15-20mm.
If I was go go down this path, I have read that extended lugs are required. Suggestions on which ones would be suitable would be appreciated.
As for the rims, I have a set of 14" BBS Mahle. I know a lot of people have/prefer the mono-blocks but I like the style of these.
Different folks, different strokes.
1988 420SEL - Agnes
Re: Lowering the 420SEL
Post by CraigB » Wed 10 Jan, 2018 11:18 pm
My gut feeling is if the shocks feel fine to you now, they will also work fine with the new springs. Don't think i can add anything else.
Do your 14" BBS fit over your front brake calipers? Gen 1 14 inch wheels won't fit over the bigger calipers and discs on your gen 2 420, so was just curious that they have that extra clearance. I like the BBS too and apparently what was first fitted on my 500SEC AMG, except in 16 x 8
420.SELect
Post by 420.SELect » Wed 10 Jan, 2018 11:39 pm
Hi Craig.
Yeah I think the shocks feel fine at the moment.
Might just chuck the new springs on and go from there.
As for the clearance concern, the BBS’s are currently on so I assume I am okay.
When I chuck the new springs in I will have a look a see what the clearance looks like.
Chris
1988 420SEL - Agnes
