all electric windows not working
Post by CraigB » Sat 09 Dec, 2017 12:26 am
I tried searching this - lots of things about electric windows but couldn't find this problem. This is on a 1982 500SEC and out of nowhere all electric windows stopped working. I checked a few things like fuses and loose connectors - but all out at once I thought limited sources. Checked out wiring diagram and got the idea about relays - E and F are the ones related to the windows. I swapped in a spare and found 'F' was the problem - all fixed but wish i had tried relays before pulling the console apart to get to plugs on switches! Hope this post saves someone else the hassle. And to ID relay letter, it is faintly cast into the fusebox like the fuse numbers and also if you pull them out it is written underneath quite clearly.
Honey500
Re: all electric windows not working
Post by Honey500 » Mon 11 Dec, 2017 12:36 pm
Hi Craig,
Thanks for the post, quite helpful. I take it though that if it is the relay none of the windows work? Rather than the 1 window that is not working on my series 1.
Post by CraigB » Mon 11 Dec, 2017 1:22 pm
Yes that's right. For trouble shooting one window I would pull the switches from the console and swap them left to right - basically you just want to be able to take the plug from the window not working and plug it in to another switch - it will fit the other side. If it works, you can pull the other switch apart and clean up contacts etc or buy a new one. If it makes no difference then you are probably looking at a motor thing. If you have a multimeter you can check if power coming through to motor etc.
Honey500
Post by Honey500 » Mon 11 Dec, 2017 1:46 pm
Thanks Craig.
Was chatting to a mate re: testing with a multi meter. Knowing my car I will probably open up th door and find no motor at all!!!!
Post by CraigB » Mon 11 Dec, 2017 2:02 pm
easy first test though, just lever out the switches and do some swapping before you pull anything else apart - could just be a dirty switch or even a wire off.
Honey500
Post by Honey500 » Tue 16 Jan, 2018 12:17 am
Ok so need some advice from the brains trust.
Today on a perfect Adelaide summers day took Sadey out for a decent run and became inspired to do some work on the busted front window when I got home. Have checked switches and appears to be an issue with the motor. I got the multi meter out and when operating the switch I get 12v on the elec contacts so I conclude it is the motor. Undid 2 screws in the botom and then basically unscrewed the unit.
Question is based on the pic is this all I need to remove? Doesn't seem big enough.
Second question is whether it is worth heading out to upullit (pick a part) and removing a motor? Any way of testing that motor without taking a car battery with me?
Post by CraigB » Tue 16 Jan, 2018 8:45 am
i don't know but would imagine the motor is same as sedans and there is usually at least one of those at upullit - can check stock list too. That's all you need I think. And testing, there is usually a rack of batteries for sale at upullit - just need a couple of wires! And if the same, I would take a back window motor or at least passenger side.
Honey500
Post by Honey500 » Tue 16 Jan, 2018 9:30 am
Thanks Craig, last time I visited there were a few. Sounds like a trip might be in order!
Post by 420 SE » Tue 16 Jan, 2018 3:02 pm
From memory, there are two different motors which were used.
It would pay to take your broken one for comparison.
Honey500
Post by Honey500 » Tue 16 Jan, 2018 8:30 pm
Good suggestion, thanks Ross
Dean 560 SEC
Post by Dean 560 SEC » Wed 17 Jan, 2018 1:29 pm
If youre after a front left SEC window motor I should be able to help you with one.
Dean
Current Garage
1987 560 SEC (ECE)
1982 XJ6 Jaguar
2007 E90 BMW 530i
2004 E46 BMW 318i
