Dual Air Intakes 420
ngruzevs
540 K
Post by ngruzevs » Mon 25 Sep, 2017 5:49 pm
I'm in the process of installing dual air intakes on my 420. I've acquired a dual air intake assembly and have the smaller long flexible pipe, but struggling to find the right air intake scoop (passenger side) part.
Does anyone have the part number for the passenger side air scoop?
Current Garage
gazman
Re: Dual Air Intakes 420
Post by gazman » Mon 25 Sep, 2017 7:09 pm
If the gods smile on me I'm buying a 560 for a "spares" when I return from work (mid oct) if the bit you want is there and I suspect it is it's yours.
Or forum sponsor ex Germany
1989 560 SEL King of the road
Dean 560 SEC
Post by Dean 560 SEC » Mon 25 Sep, 2017 10:07 pm
HI Nick
This should be the once you're after
http://www.ebay.com/itm/NEW-Mercedes-R1 ... SwzaJX71WT
The part number is in the description.
DR
Current Garage
1987 560 SEC (ECE)
1982 XJ6 Jaguar
2007 E90 BMW 530i
2004 E46 BMW 318i
ngruzevs
540 K
Post by ngruzevs » Mon 25 Sep, 2017 10:55 pm
Thanks Dean, I'm actually looking for the air scoop that clips in next to passenger headlight.
I have the flexible hose as can be seen in attachment.
Thanks Gary, will happily pay you for scoop if I haven't found one by then.
Current Garage
ngruzevs
540 K
Post by ngruzevs » Wed 04 Oct, 2017 9:01 pm
I've manage to source a passenger air intake scoop
FYI, part number is 1170940911
Gary, appreciated your offer, but I'm all good now.
Current Garage
gazman
Post by gazman » Wed 11 Oct, 2017 7:55 pm
Glad you got one. Missed out on the spare 560 anyway, one of the many joy's of FIFO :boohoo:
ngruzevs
540 K
Post by ngruzevs » Tue 17 Oct, 2017 6:01 pm
I've fitted the new air intake housing and associated scoop and hose. I'm guessing any power gains will be very modest ~5HP, but would be happy to hear otherwise
Current Garage
ngruzevs
540 K
Post by ngruzevs » Fri 20 Oct, 2017 9:37 am
From around 87 all euro 420s had the dual intake setup, power and torque climbed to 170KW/335NM, compared to Aus delivered versions 155KW/317NM.
Current Garage
Post by kimrh » Fri 20 Oct, 2017 10:33 am
The dual intake gives the engine bay a more aesthetic (balanced) look but i doubt whether it would lift performance figures.
The best mod especially for Aust delivered models is to ditch that horrible factory crossover header design and go for twin dumper Euro logs or Tri-Ys if you can source them and a custom free flowing exhaust set up in 2.25" under the car ditching those heavy Kidneys
Post by AMG » Fri 20 Oct, 2017 8:28 pm
from 09.85 all RUF and ECE spec m116 and m117 engines had improved performance over the Australian versions.
the performance came from compression ratio increases, improved camshaft profile, fuel divider delivery piston metering, EZL maps and exhaust.
the dual intake improvement was to decrease pressure drop at the filter element and more importantly act as a cold air induction source.
