Wanted! Gen 1 380SEC Pristine RH Window Switch
mrsecman
Post by mrsecman » Wed 13 Sep, 2017 11:12 pm
All. The decals have chipped off this switch. I'm told the only solution is to replace the switch so it looks nice and pristine. The LH window switch is still excellent. Has anyone got a spare RH switch assembly to sell? Many thanks! :-)
mrsecman
1984 380SEC ('83 Update) - Thistle Green, Top Condition, 2-1/4" Magnaflow Exhaust w/HiFlow Centre Mufflers, Interior Modifications
1994 Honda Accord VTi-S - Daily Runabout - SOLD 2015 (Good New Home) - Thanks for the Service
Re: Wanted! Gen 1 380SEC Pristine RH Window Switch
Post by T-Modell » Thu 14 Sep, 2017 4:37 pm
HI,
I would try German Ebay; here in Germany (where the steering wheel is in the correct position :laughing6: ), it's the other way round ... the left switch is normally used much more. Search for "mercedes w126 schalter fensterheber"
https://www.ebay.de/sch/i.html?_from=R4 ... r&_sacat=0
Post by CraigB » Thu 14 Sep, 2017 8:11 pm
Have a look on ebay etc, you might be surprised how cheap aftermarket ones are. I will have a look what i have (I see you are in Adelaide), but usually they show signs of wear.
Post by T-Modell » Thu 14 Sep, 2017 8:12 pm
One tip for aftermarket: There are "cheap" ones, which aren't lit; so check the text of the offer.
mrsecman
Post by mrsecman » Thu 14 Sep, 2017 11:08 pm
Thanks for the advice folks! Will hunt around, see what I find. I'm bound to find it eventually. It's possible to get NEW but they're about $180.00 and I'd rather spend that on something else.
mrsecman
Post by T-Modell » Thu 14 Sep, 2017 11:11 pm
this one's new, aftermarket, not lit ... really expensive :laughing6:
http://www.ebay.de/itm/Mercedes-Benz-W1 ... Sw4shX9hzD
Post by CraigB » Fri 15 Sep, 2017 8:34 am
Not that i can read German, but looks like this might be the ones you are looking for and looks like a pair
http://www.ebay.de/itm/Schalter-Fenster ... 100623.m-1
Probably not lit..... but then you should be looking at the road anyway and not your window switches!! I know how to find mine in the dark anyway!
bahnstormer109
Post by bahnstormer109 » Fri 15 Sep, 2017 10:11 am
You can also pop out the buttons on these and swap them with the buttons from an aftermarket switch so you have the improved cosmetics from a cheap aftermarket switch with the quality of your original body/mechanism.
Paolo
Brisbane
72 300SEL 3.5
82 380SEL
84 280CE
86 560SEL
86 230TE
A good Benz these days is hard to find, so please be gentle with this Benz of mine.
Post by CraigB » Fri 15 Sep, 2017 10:39 am
Thats a good idea and if translucent the light is in the switch and might work. Alternatively a rear window rocker bit might fit too and much less likely to be worn.
Post by T-Modell » Fri 15 Sep, 2017 5:44 pm
Those are the ones without light; in due course I will try to 3d-print those inlets; the symbols for windows are designed already; The test with black and translucent filament still to be done ...
Post by CraigB » Fri 15 Sep, 2017 6:42 pm
I was thinking the rear button of the front switch block - thinking the front one most likely to be worn. But thats great if you can make replacements just for the bit that wears.
mrsecman
Post by mrsecman » Fri 09 Mar, 2018 1:44 am
What's absurd about this is it's only the circular window decal covering that's worn off - the light still comes through and whole switch works fine. Chips and wear on the "decal" look tacky though. Amazing how something so simple requires so much effort or different method.
I might check out a hobby shop - if I can find back decal cover I may be able to fashion something.
mrsecman
hi ho
Post by hi ho » Fri 09 Mar, 2018 3:18 pm
Hmm there should be an easier way -
I'm pretty sure the rocker switch part comes away easily (pop the dowel on each side)
from the main part of the switch box (I'm sure I've done this years ago)
Get a brand new after market switch on ebay -
I've seen them available for 12 bucks (Aussie) for BOTH full switches - Free delivery!
Pop the old rocker switches out and replace - just watch you don't lose the ball bearings!
