Help Diagnosing Drive Issue 240D 4 Speed Man
- Pagoda
Hi all,
I would like some help from the brains trust on a issue I've just had with my newly acquired '81 Sahara Yellow 240D 4 speed manual. The car has been in storage for many years, I've just got it back on the road.
I was driving on the freeway at 100km/h, and had been doing so for a number of hours. I suddenly lost 4th gear - it was as if the car had popped into neutral. The engine would rev freely, but I had no drive. I pulled over into the emergency lane. I could grab first, but it felt like the clutch was slipping a little. Shifted into second, and I lost drive again. The car was towed to my mechanic this morning, he drove it for around 8km and said it was fine - no slipping, no loss of drive.
My first thought (naturally) is the clutch, but it just seems odd that it would completely disengage without warning on me, and then behave fine when relatively cold. What are everyone's thoughts? Is there some other component that I'm missing? that could result in the above symptoms. Clutch will be replaced anyway, but I just thought I'd check in case I'd missed something.
Any insight appreciated!
W123 300D – The White Maiden (Regretfully Sold)
W115 220 – The White Maiden II
W124 260E - New daily
Located: Melbourne, Victoria.
- 300 SLR
Re: Help Diagnosing Drive Issue 240D 4 Speed Man
Shifter linkages ?
- Bartman4800
- SLS AMG
Just a thought:
the clutch is hydraulically operated, using brake fluid
If there is too much fluid in the reservoir, it can start operating the clutch when it gets hot. The same happens with brakes.
my 0.02, Bart
my 0.02, Bart
2012 W212 E250CDI
2012 W212 E250CDI
- Pagoda
Shifter linkages were replaced by my mechanic I was told, but there is definite play (up-down) even when in gear on the shifter. I tried going back into 4th while coasting to no avail, so not sure that's it. I will persue though
- Pagoda
Interesting, definitely something to be aware of. Mine doesn't appear to be overfull. It's below the "max" line and sits about where the seam between the two halves of the reservior are (i.e., just below max).Bartman4800 wrote: ↑Thu 11 May, 2023 3:49 pm Just a thought:
my 0.02, Bart
- Bartman4800
- SLS AMG
That is an image of the brake fluid reservoir. Are they shared in your car?
2012 W212 E250CDI
2012 W212 E250CDI
- 300 SLR
W123's share the fluid reservoir
- Bartman4800
- SLS AMG
OK, so that's not the issue.
Another possibility is a collapsed hose to the clutch slave.
Look for dry rot on the hose and replace if needed
Regards, Bart
2012 W212 E250CDI
2012 W212 E250CDI
- Pagoda
I'll put the car on ramps once I get back from Sydney and report back. Thanks for your assistance insofarBartman4800 wrote: ↑Thu 11 May, 2023 8:05 pmOK, so that's not the issue.
Regards, Bart
My favourite is the collapsed internally flex line. Years ago(like more than 40!) I had one on a brake, that acted like a valve, so fluid pushed past under pedal pressure to lock it on and then very slowly returned. It could fit your description. Perhaps when cold, pump the clutch pedal many times first, then try and drive and see if normal or lacking drive. They are cheap and probably never been replaced!
- Bartman4800
- SLS AMG
I had one hose on my finny that was so blocked that it resisted full pressure (never pushed that hard on a brake pedal before) until it went pop and the side wall of my shed had an oily spot. The steel tube to the rear brake slave was disconnected to figure out why that wheel was not braking...CraigB wrote: ↑Fri 12 May, 2023 5:26 pm My favourite is the collapsed internally flex line. Years ago(like more than 40!) I had one on a brake, that acted like a valve, so fluid pushed past under pedal pressure to lock it on and then very slowly returned. It could fit your description. Perhaps when cold, pump the clutch pedal many times first, then try and drive and see if normal or lacking drive. They are cheap and probably never been replaced!
2012 W212 E250CDI
2012 W212 E250CDI
