electric window regulator
- 450 SEL 6.9
- Model you own: w123
as the title says. My '75 450 SEL drivers side window regulator is cactus. The motor is fine but I guess at nearly 50years old its been a good unit. I reckon by the sound of the gears not meshing that the alloy frame is bent. I had removed it a couple years back to replace the motor and while it was out straightened it and I lubed everything with a good dry lube and its been ok but now need to buy a new (used) unit so can anyone give me a lead to one? Is one from a 280se a fit so maybe another option?
I'll also post this on the Topklasse site to widen the search.
Pete
Pete
1978 W123 300D Maple Yellow
1983 W123 280TE Champagne
1975 W116 450SEL Silver blue
- T-Modell
- die Nützlichkeit Meister
- Model you own: w107
- Region: EU- Western
Re: electric window regulator
Hi Pete,
same with me here and the ute. This part is afaik not aluminium, but a foundry part. So repair impossible. I bought used ones from the club, but whatever you buy it's 50 years old too. I paid twice and the new ones are working.
I'd bite the bullet and spend 500 EUR for a new one; check if A1167201246 is the correct number ... should be still available.
Kind regards
Old and new:
Kind regards
Old and new:
Unless you can fluke finding a used one that was only replaced 5-10 years ago, whatever you get is going to be bent and have a limited lifespan. You could try LHD countries as there's will have less wear? Or as Thomas says go a for a new one, they you should be set for life with it.
- 450 SEL 6.9
So I guess the W123 version is different? Would the one from my rear door fit the front? Unfortunately I am not in a position to buy new at the moment.
- T-Modell
As far as I can see here on Ebay, the front and rear are different.
Well, even used ones here are around 100 EUR with the problems mentioned above, e. g. https://www.ebay.de/itm/334848278325?ep ... R9i9t976YQ
Here's one from the rear, looks different to me:
https://www.ebay.de/itm/234515075069?ha ... R9i9t976YQ
- 450 SEL 6.9
OK Thomas, thanks for checking. Having most of the tools I need I have thought of casting one myself and maybe a bit thicker using the piston alloy as its a stronger alloy. Once I remove the unit I'll see what I can do in that area or even reinforce the one I have somehow. Failing that I'll have to save for a new one as suggested but with our pacific peso exchange rate it may become unobtainium. The age pension has some downsides here.
- T-Modell
Hi Pete,
I understand, just wanted to share my experiences with it. I bought two used ones from the club - around 100 Euros each. Didn't see, that they weren't ok and didn't even know, that they were available new from MB (W108).
In your case I'd recommend to find a "better" used one, that might work for a while. If I can be of help in case you want a used part from Germany, then let me know.
- 450 SEL 6.9
Thanks Thomas
Now that would be an interesting exercise. There was a guy talking about CNC machining the frame at one stage. I think the biggest challenge would be to find one that is not bent as the pattern.
- 450 SEL 6.9
Very true John. I have the old one stripped out and attempting to make a wooden pattern. I think its doable but its all ahead slow at the moment. Just a question but would a unit from a W123 fit?
I doubt it. The geometry to make these work is precise. I can see other model regulators fitting, but not working correctly.
I need to make time to go to upullit and get a drivers door. Will see what is inside it. Hopefully this week.
- 450 SEL 6.9
Cheers Craig more than happy to wait but if its an ok 1 and you want to sell it I'm happy to purchase it.
- Bartman4800
- SLS AMG
- Model you own: w111
The easiest way to go these days, is to have the original part scanned with a 3D scanner. There are companies that can do that for you.John Green wrote: ↑Sun 07 May, 2023 4:16 pmI doubt it. The geometry to make these work is precise. I can see other model regulators fitting, but not working correctly.
That point cloud then gets converted to a 3D CAD file, which is then made into CAM code to send to a 5 axis milling machine.
Making a wooden pattern will only introduce extra errors.
Regards, Bart
2012 W212 E250CDI
2012 W212 E250CDI
- 450 SEL 6.9
Hi Bart, I did think of that so once I get a replacement (hopefully) I will do a 3D scan with my revo scanner (pop 1) and get it cnc done. My cnc is only a hobby unit 300x240 and only does wood. The issue is trying to straighten it without it breaking as the material is not really malleable enough. The casting part is the easy bit.
- Bartman4800
- SLS AMG
Hi Pete,Pete49 wrote: ↑Fri 12 May, 2023 1:23 pm Hi Bart, I did think of that so once I get a replacement (hopefully) I will do a 3D scan with my revo scanner (pop 1) and get it cnc done. My cnc is only a hobby unit 300x240 and only does wood. The issue is trying to straighten it without it breaking as the material is not really malleable enough. The casting part is the easy bit.
Casting still makes for a weak material. If you have it machined out of billet (alu 5083-h111 or h116) it would be far stronger.
However, it's then probably cheaper to buy a new one...
2012 W212 E250CDI
2012 W212 E250CDI
- T-Modell
+1 ... with the ute's motor holders it was the milling time (8hrs) that did the cost. 1,000 EUR cash, the steel block was close to nothing.Bartman4800 wrote: ↑Fri 12 May, 2023 3:15 pm ...However, it's then probably cheaper to buy a new one...
