Hi Team,
'this should be the world's easiest thing to do, but for the life of me I can't get the new LHS front indicator lens to stay in.
Can someone tell me what the elaborate tab highlighted below, is supposed to connect to?
The original fell out on the highway the other day, so I don't have a removal memory to refer to.
Dweezil
W124 front indicator replacement
- C 111
- Region: New South Wales
- Christo C
- Zeppelin
- Model you own: w124
Re: W124 front indicator replacement
Have a look at the other side!
~Christo
Beaconsfield, SYDNEY
- C 111
Can't really see what's happening on the other side, either. Pretty hectic in there, and my eyesight is failing me.
- 300 SLR
On my W202, it clips into the chassis - How did you get the old one out ?
So long as you have the two tangs inserted into the apertures on the headlamp, then if should just be a matter of pushing it back until the "elaborate clip" pops into place. There is a small raised section on the inside of the guard that it clips onto.
The one in your picture looks like an after market one, so maybe that is the issue?
