E220 over fueling
- RavzSa
- S Class
- Model you own: w124
E220 over fueling
Hi All,
Took the car out for a drive this weekend after a few months and noticed that the car is burning rich. I can distinctly smell a strong petrol smell from the exhaust.
From what I understand the ECU controls all of the fueling with info from the MAF. Fuel consumption was also pretty high.
I checked for error codes and didn't pick up any.
Could the MAF be faulty without reporting an error and could there be any other item that could cause this?
R
R
- Bartman4800
- SLS AMG
Re: E220 over fueling
Try some injector cleaner first, poor atomization leads to black smoke.
Can you send some pictures under the bonnet? Earlier W124 had CIS, but yours might have multi point injection...
2012 W212 E250CDI
2012 W212 E250CDI
- RavzSa
- S Class
Thanks, I shall try the injector cleaner.
Do you think theres any benefit in using a MAF cleaner as well?
Photos of engine bay below
- Bartman4800
- SLS AMG
Yes, the MAF sensor is situated just behind the air filter box. Buy some sensor cleaner; if it does not help, there's nothing lost
2012 W212 E250CDI
2012 W212 E250CDI
The early HFM system didn't have a lot of error codes that were helpful. One of the first things I would check is that the engine is getting up to operating temperature quickly (87deg) and that the coolant temp sender for the HFM module is reading correctly. Either being wrong will make the HFM module think the engine is cold and keep the mixture rich. Kind of like the coke being on when it shouldn't be.
- RavzSa
- S Class
Would you know which is the coolant sensor for the HFM, i changed to single / double pole sensor but was told there is another sensor?John Green wrote: ↑Mon 21 Nov, 2022 9:54 amThe early HFM system didn't have a lot of error codes that were helpful. One of the first things I would check is that the engine is getting up to operating temperature quickly (87deg) and that the coolant temp sender for the HFM module is reading correctly. Either being wrong will make the HFM module think the engine is cold and keep the mixture rich. Kind of like the coke being on when it shouldn't be.
- RavzSa
- S Class
Also, the cold start idle / choke, stopped working years ago... not sure if this is linked to this sensor
Even after rebuilding the throttle body it didnt work again
As in you changed from a single to a double pole? If you didn't replace like for like, I would suggest that is the first thing you should correct. Sensors can be quite fussy and need to be the same and either genuine or OE quality.
- RavzSa
- S Class
I replaced all 3 coolant sensors this weekend with OE (Topran) - like for like
Didn't seem to make a difference but at least Iis all new now
