I have been having intermittent fan operation: slap the dashboard or under the glovebox and it goes - for a while. The donor car (Sth Africa) had a Smiths motor(!), about 20mm longer, same dia, so won't fit without a day of cutting and brazing to make it fit. Last resort. There is no part number stamped on the side.
Graham
Is it worth my while to put in a 12v brushless motor of similar or smaller dia and/or length . There are only 2 wires in - power and earth. Would it stuff up the resistors that govern fan speed?Heater fan motor
- E Class
Heater fan motor
Re: Heater fan motor
I should have a used fan at work.
- E Class
Cheers!
- 300 SLR
You can pull the motor apart and replace the brushes.
See the metal tabs on the side, then can be punch upward so that the lid comes off. You can grease the bearing while you are at it. Then punch them down again. I got brushes of fleaB, had to solder them in and re-use the original springs.
New Brushes = another 40 years of service ......
- GrampiansMerc
- M-100
Same as Tim
Clean and check brushes and you should be all good - mine was.
1980 w123 300D Silver sedan
1980 w123 300TD "Anna" - sold
1979 300D - sold, gone to be restored
2006 Musso - Korean Mercedes, 5 cylinder diesel - Blown head gasket, buggered motor, grrrrrrr (I will stick with German Mercs)
I'm just a simple man trying to make my way in the universe
