W202 Key Fob
- 300 SLR
- Model you own: w123
W202 Key Fob
I have lost one .... Does anyone know where can I get one and have it programmed at a cost less than the price of a second hand W202
- Maybach
- Model you own: w202
Re: W202 Key Fob
What state are you in?,
I had to replace mine,
I got a local locksmith who came out&cut it on the spot&reset it.
- Maybach
Re: W202 Key Fob
Call German Star in Reservoir ,
They've got the number of a bloke who they use&who i've used.
- 300 SLR
Re: W202 Key Fob
Thanks,
The generic lock smiths are quoting $450 for a programed replacement fob
MB in Fairfield will do a genuine one for $550 - Gotta show my rego papers etc
Spoke with Max at German Star (nice guys) and he said his guy is about that cost.
You can buy a blank fob for $20 from China and Autel IM608 key coder for locally for $4,700 ($3K imported_). This tool does all fobs so would be useful for a mechanic but is not cost justifiable for me.
You can also buy a specific tool for the W202/W208/W210 for $1K from CGDI, which also does "mileage correction" Hah - We know what that means .... It'[s a shame cause I'll now never believe the electric ODOs if this is the case
I will have a long hard look for the lost one as $450 is a lot for a key ....
Re: W202 Key Fob
Get your wife/partner/mistress/girl friend/etc to look. That usually works for me.
- Christo C
- Zeppelin
- Model you own: w124
Re: W202 Key Fob
Especially when you get all four involved working as a team.
W124.023 1986 230E M102.982 Thistle Green Saloon "Janis" 345,678+Km
Beaconsfield, SYDNEY
Re: W202 Key Fob
I'm impressed JG - you have all those four.... just a bit worried about what the etc. is.... the dog?
- 300 SLR
Re: W202 Key Fob
As happenstance would have it, the fob failed.... (No IR bleep using the phone). Pulled it apart and tried every trick known to the internet. Dead. A thorough search by myself and 1 other could only yield the blank and an extra metal key
I found someone who stopped by and cut two keys off the Ignition module. Being a W202, no ODBII module to read the IR data, had to extract it via the IR sensor on the barrel. Also advised me that the ignition module being so old could fail and the only real option (given how old it is) is to go to the dealer. Don't bother getting one from a wreckers as it is likely to be just as close to failure.
$540 for 2 FOBs, with metals Keys, 12 months warranty. They are not genuine MB fobs but electronics is electronic the cases are good quality.
Re: W202 Key Fob
If broken - Generally dry joints on the circuit board or poor connection on the battery terminals.
I've fixed a few of these when broken
Not so long ago they were only $220 each at 3 Point Fairfield and then suddenly price ramped up to over $500.
MBA policy.
MBA policy.
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
- 300 SLR
Re: W202 Key Fob
Thanks - Fairfield wanted $560, 2 weeks and payment upfront. I have the old one pulled it apart, will see if I can get the emitter to work.
- SantoC
- Pagoda
Re: W202 Key Fob
You could try Aust ECU repairs. They only deal with electronics pertaining to Mercedes.
They can make and copy fob keys cheaper than dealerships.
https://australianecurepair.com.au/contact/
