Vibration in "D" when cold
Grumpy
Model you own: w210
Post by Grumpy »
I am wondering if anyone can shed some light on my issue. When cold my E320 2000 model , I can feel a vibration through the driveline when stationary (only with "D" selected). If I select "R" or "N or P " it goes away instantly. It sought of feels like reverse is still partially engaged, but that's just to describe what it feels like. I have changed the auto oil and filter including the converter oil. It was a waste of time as they all looked like new, perfectly clean. This didn't make any difference. If I select W/S, no difference. Apart from the SRS light on, it goes perfectly well.
Thanks for any ideas. Kel
The Liver is Evil & must be Punished
W210 Elegance E320
Grand Cherokee Jeep
Chrysler 300C Mercedes OM642 V6 Diesel and drive line.
Departed - W201 190E
Re: Vibration in "D" when cold
Post by John Green »
First thing I would look at is the transmission mount. These are a poor design from day one and a common failure. Get underneath and grab the tail shaft just behind the transmission. You should be able to flex it up and down by hand. My guess is that there will be no down movement as the transmission mount has bottomed out.
Grumpy
Model you own: w210
Post by Grumpy »
John Green wrote: Fri 10 Jul, 2020 5:46 pm First thing I would look at is the transmission mount. These are a poor design from day one and a common failure. Get underneath and grab the tail shaft just behind the transmission. You should be able to flex it up and down by hand. My guess is that there will be no down movement as the transmission mount has bottomed out.
Thanks John, I'll try that soon . I should have thought of checking it. :)
W210 Elegance E320
Grand Cherokee Jeep
