new 114
- S Class
- Model you own: w114
- Region: South Australia
new 114
So ive rescued a w114 280 sedan which has been dormant for a number of years
need some TLC and hoping the wise people on this forum can help
so be prepared for lots of questions :)
drove it home today and noticed a few things
front suspension , seems very soft and spongy. lots of play in the steering wheel
assume all the rubbers in the front are gone ? any idea ?
Transmission - havent done a filter kit through it yet ,but noticed it over revs when going from 2nd to 3rd ? again any ideas
Rear suspension , had a look underneath and looks ok as they are replacements.
Brakes - all good , replaced the pads and brake hoses, cleaned the calipers and replaced the fluid
engine , oil and oil filter replaced , new sparks and leads
diff , replaced diff oil
interior , seats are clean but have lost their firmness . door cards and roof lining need some work. dash cracked.
body - the worst part -- -needs new floors all round and rust removed from spare wheel well. Looking to source new floor pans from overseas and somehow rescue the brackets for the accelerator, seat frames and handbrake
zf friedrichshafen
- pastelgrey300D
- Maybach Exelero
- Model you own: w111
Re: new 114
Nice find - I like the colour! Is it the single or twin cam 280 engine?
Front end sounds like you will most likely be up for shock absorbers (they are probably ancient anyway).
Steering play could be a combination of worn tie rod ends and worn linkages, worn idler arm bushings, they are all still available new and relatively cheap. There is also adjustment in the steering box itself that can take up some of the slack, but you don't want to tighten it up too much otherwise you risk the gear jamming and/or the steering won't self-centre after turning a corner. Also, check the coupling between the steering column and box - they can wear out pretty easily and once the bushings go you'll get lots of slack.
1967 W111 230S - Horizontblau
1963 W110 190c - Custom Wagon Conversion (work in progress)
1983 W123 280E - About as modern as I dare to go (rolling resto project)
- S Class
- S Class
Re: new 114
So the car needs the floor pans replaced
a few crash shops ive spoke to suggest new pans , rather than cutting out old ones
can anyone recommend a place to source new floor pans ( not just the sections )
found a few places overseas, but they are for LHD vehicles ( does it matter ? )
zf friedrichshafen
- Dernburg Wagon
Re: new 114
Got the same rust issues with my '70 W114. And dash problems. I could only find floor sections not whole floors. No one seems to have any in Oz. You can find them in the U.S to Iran.
- Große
- Model you own: w123
- S Class
Re: new 114
So update
floor pans being replaced at the moment with some out of a parts car.
New front and rear windscreen rubbers ordered and a set of door rubber seals
Set of new shocks on their way too
zf friedrichshafen
- T-Modell
- die Nützlichkeit Meister
- Model you own: w107
- Region: EU- Western
Re: new 114
You seem to have fun with wiring too
P. S.: Any connections to ZF? My daughter works there ...
- S Class
Re: new 114
Wiring shouldnt be a problem , its just all the centre console wiring ( lights , heater/aircon etc )
and yesT-Modell
I worked at ZF Lemforder when they had operations in Australia...
Alas , with the collapse of the auto manufacturing industry here , ZF operations scaled back dramatically and all they have is ZF service distribution centre
The only positive , is that the old ZF factory and a small number of workers( a lot were made redundant ) are now associated with this
https://www.abc.net.au/news/2018-05-03/ ... de/9722170
and yesT-Modell
zf friedrichshafen
- pastelgrey300D
- Maybach Exelero
Re: new 114
If you are after more parts, there's currently a W114 230 sedan at Upullit Gillman. Engine and trans are gone but still a few bits.
- S Class
Re: new 114
Think that one at upullit has had most of the good bits removed
Another keen buyer picked up the manual gearbox out of it
zf friedrichshafen
- S Class
Re: new 114
zf friedrichshafen
- S Class
Re: new 114
zf friedrichshafen
- S Class
Re: new 114
zf friedrichshafen
- AMG
- OZBENZ Admin
Re: new 114
Getting stuck into it I see
progress is rewarding and looking good.
107.048 722.313 Signalrot Stella
124.051 716.62 Perlblau / Iceblau Gretel
201.034 717.404 Blauschwarz Hermann
212.074 722.931 Diamantweiß Klaus
124.090 722.358 Malachit Grün Beatrix
126.039 Anthracitgrau "Schultz" - In Mercedes Heaven
201.029 Signalrot "Sabine" - has taken ownership of Andrew's Garage
107.023 Astralsilber "Lurch" - now in the loving care of Craig B
201.035 Blauschwarz (parted) formerly owned by Derek/Hasan.
- S Class
Re: new 114
coming along
thats most of the structural stuff done...
next is rust proof it ( por15 etc ) , then some dynamat then carpets
still got some smaller bits under the dash ( on the passenger side )...suspect the windscreen seals are to blame for this..
hoping that i dont have to pull the dash out
zf friedrichshafen
- S Class
Re: new 114
Well Im now at the cross roads with this....
the mechanic who was going to do some suspension work on thr front advises i should scrap it
it has rust on rh and lh rear inner wheel arch , radiator support , chassis rail where steering box mounts.
the floors have some small spots underneath
i've have front inner guards and boot repaired
zf friedrichshafen
- S Class
Re: new 114
Decision has been made
no more 280 w114 , going to part it out and use what parts are available
got a w115 now , 240d.
zf friedrichshafen
