Hi guys,
Can someone recommend a good source for engine gaskets and seals. I'm after rocker cover gasket, front and rear main seals, exhaust gaskets, inlet manifold gasket and probably a few more.
Steve
280s engine gasket set
- C Class
- Bartman4800
- SLS AMG
Re: 280s engine gasket set
2012 W212 E250CDI
2012 W212 E250CDI
- C Class
Cheers Bart, they don't appear to list any engine gaskets though.
- Bartman4800
- SLS AMG
Send andreas an Email, he can get just about anything for you.
This is in his "motor dichtsatz" (engine gasket/seal kit)
For gasket you cannot get, I would say get a roll of gasket paper and some aviation gasket cement. That will do the trick!
https://www.ebay.com.au/p/Permatex-Avia ... 624&chn=ps
2012 W212 E250CDI
2012 W212 E250CDI
- C Class
Fantastic, cheers Bart.
