Recently bought a Mercedes 74 W114 280E!
rx22nv
Post by rx22nv » Fri 06 Jul, 2018 12:27 pm
Hey folks, I'm Dan and this is my First post after being a member for a few years. Been looking for a W114 280e for a long time and finally found a good match.
She is in pretty good shape, floors are clean, paint is pretty decent overall. It's been sitting for a long time and I need to do a few things before I put her back on the road. I'm not new to cars but this is my first Mercedes so I'll need your collective help to get me up to speed.
Here is a photo of her the day I bought it:
Re: Recently bought a Mercedes 74 W114 280E!
Post by TheMadRacoon » Fri 06 Jul, 2018 11:18 pm
One of my favourites. Had mine almost 10 years. At almost 500,000 km she felt she could do it all over again. And ohhhh so reliable!
Post by T-Modell » Sat 07 Jul, 2018 4:12 pm
Hi Dan,
welcome here, your car looks great! Good luck with restoring it and I do hope, no "dramas" come up. Maybe post some more photos ... do you have factory aircon in it? If yes, I'd be interested in a centre console pic ...
Kez
Post by Kez » Sun 08 Jul, 2018 5:26 pm
Ok, so I'm just a tad envious given I've just posted that I'm on the hunt for something similar.
However, she looks lovely. Looking forward to seeing more photos and details of what you need to do to get her going properly.
rx22nv
Post by rx22nv » Mon 09 Jul, 2018 11:38 am
Thanks for the comments!
I notice MB spares is currently not selling parts. Is there other good Aussie suppliers for parts? I've found Pelican parts, Niemoller.de and of course ebay.
Current issues:
She is running a little rough but I won't worry about that too much until I can run the old fuel out of it.
Brakes are hard. Some research found the Mercedes source website and indicates to check the rubber seal between the master and the booster. I separated the master cyl (without disconnecting the brake lines) and found there is no O ring there. (It's a 40mm one if anyone else is going to try) I couldn't get the booster out far enough so I'll have to wait until I can disconnect the brake lines. Anyone else encounter this? Hopefully the booster isn't dead!
I have a fuel line that is weeping. The one on the cold start injector. Anyone know what size that rubber braided hose is?
It does have the air con that I assume is factory but doesn't have the bulged out console like some do.
I'm also after an original AC condensor and electric fan. This aftermarket core has been installed and is mounted pretty horribly.
Post by Bartman4800 » Tue 10 Jul, 2018 7:42 pm
Usually a hard brake is a sign you don't have any booster action.
A quick check whether a diaphragm is ruptured: after the engine ran, pull the hose out of the booster.
You should hear a hissing noise of the air rushing in. Reinstall the vacuum hose
When you put your foot on the brake pedal, and you start your engine, your pedal should sink a little.
Yes there should be a seal between the booster and the master cylinder, or you loose vacuum.
rx22nv
Post by rx22nv » Tue 10 Jul, 2018 8:51 pm
It does sink a little when I hold the brakes and start her up. I'm reluctant to pull the hose off just yet, I'm worried about tearing that clear plastic hose.
I guess I'll try the simplest thing first and install a seal and see where I end up.
Anyone ever had one rebuilt?
Post by AMG » Tue 10 Jul, 2018 10:22 pm
the booster hose has a one-way checkvalve in it which can fail. undo the nuts on both ends (booster end and manifold) and blow through it to check both directions. obviously the flow needs to be one-way only.
you can replace the check valve with a new one 0004313507 use hot water on the plastic hose to soften it and simply pull it off.
occasionally you need a hot air gun with a bit more heat (be very careful)
Post by Chai » Tue 10 Jul, 2018 10:50 pm
Don't discount the possibility that the flexible lines to the brake calipers are original and swelled up internal, constricting it.
Check for the internal condition is to flush the brake fluid and see how easily the fluid squirts out on depressing the brake pedal.
rx22nv
Post by rx22nv » Wed 11 Jul, 2018 11:21 am
Yes definitely a possibility. I'm just going through this now with my 1969 Morris Mini Matic which has been sitting for 20 years. One of the rear hoses was completely blocked.
The check valve isn't something I had considered. Thanks for the tip about the hot water on the hose. Once I'm finished on the mini's brakes, I'll try these things and report back.
Return to “W114 and W115”
