Has anyone encountered this problem?
Post by KimB » Sun 03 Jun, 2018 12:58 pm
Re: Has anyone encountered this problem?
Post by Christo C » Sun 03 Jun, 2018 1:08 pm
Yes! Always been a problem since they started using “rattleguns” - I too have broken many tools trying to get wheels off; it’s a real nuisance if you are out in the bush and no-one else is around!
For the past 40 years I have insisted tyre “experts” do the wheel nuts by hand, and I always check afterwards just to be sure.
Post by Ivanerrol » Mon 04 Jun, 2018 12:17 am
I have a breaker bar and long 17mm socket to get my wheels on and off.
If I have a tyre repaired at a tyre shop, I then always remove that tyre and wheel from the car and put it back on.
I recently changed the wheels on my W211.
Needed to use the breaker to get every wheel bolt undone and then a rubber mallett to bash the tyre to get the wheel released from the hub.
On along trip I always bring the mallet and breaker bar with 17mm socket.
I have read forum stories of broken of bolt head from those very long bolts on '80's and '90's Benz Wheels.
I've also read forum stories of distorted wheels from over tightened bolts.
Post by John Green » Tue 05 Jun, 2018 10:54 pm
From Kent Bergsma. ....
https://mercedessource.com/news/why-we- ... o-it-right
Not if you have a set of these....
http://www.torquestick.com/cart/home.php?cat=
julian
Post by julian » Sat 09 Jun, 2018 12:12 pm
What a brilliant tool.
w123 240D auto Lang
A Discovery 3
An Outback 3L
Previously: 1977 300D, 1979 300TD, 1982 280SE, 1988 560SEL
Post by CraigB » Mon 11 Jun, 2018 10:16 am
This topic reminds me of when i built an Escort rally car many years ago and used a comprehensive publication put out by the works team, right down to where to weld and how long welds should be to brace shell just right - I guess they had lots of practice! It talked specifically about wheel nut tension and stating the main reason for wheels coming off was over tightening of nuts - the threads get stretched and reduces contact area etc .... and that they should always be set at correct tension. I know that is pretty extreme use but its just not that hard to use a torque wrench or those magic sticks of John that hopefully will become the norm for tyre places. I have the correct tension written on my torque wrench so I don't have to look it up.
