73 SLC rear electric window adjustment
NZJasonT
Post by NZJasonT » Mon 14 May, 2018 5:45 pm
Anyone know how to adjust a sticking rear electric window?
I’ve had the entire regulator out cleaned it all up and lubricated it. The glass is firmly held in its rubber and metal base frame, so loose glass isn’t the issue, the motor works fine and window goes down about 2 inches then jams.
With a bit of downward pressure from the top of the glass and the switch pressed the window goes all the way down but it doesn’t want to do this without help
The fact that it does go down and up with help suggests to me it’s an adjustment that’s needed, but I cannot figure It out
I cannot be the only person that’s suffered this frustration, ...?
1971 W108 280se 2.8
1973 W107 450 SLC
Re: 73 SLC rear electric window adjustment
Post by Tony From West Oz » Mon 14 May, 2018 11:31 pm
Based on my W123 Coupe experience:
Some times the regulator mechanism bends a little and causes the window to get stuck on its way down.
The fix is to replace the regulator mechanism.
Hope this helps,
NZJasonT
Post by NZJasonT » Tue 15 May, 2018 4:54 pm
Thanks Tony - I was wondering if it could be bent out of shape or damaged somehow by PO
I’ll pull both sides on the weekend and compare
Jason
1971 W108 280se 2.8
1973 W107 450 SLC
captainslow
Post by captainslow » Sun 10 Jun, 2018 12:13 pm
Jason,
I had this exact same problem on my 1973 450SLC. It only occurred on the right side but had the same symptoms as yours. It would go down a couple of inches then jam. It initially looked like a lubrication problem - the whole mechanism would twist and jam.
I spent ages on this. Removed the mechanism many times, lubricated it, straightened it, compared it to the working left hand side - but no success. It seemed like a geometry problem and I re-drilled some holes in the glass holding bracket to move the pivot back. This improved it, but it still jammed occasionally.
In desperation I sourced a mechanism from a more recent vehicle (I think it was a '77) and the more recent part was quite different with different pivot points. It actually looked much more flimsy than the '73 mechanism but it worked first time, every time. I have no idea why the '73 mechanism stopped working (and why the left hand one still works) but it is obviously marginal. Mercedes must have recognised this and changed the design.
BTW I did not buy a new motor, the '73 motor was fine.
The guide bars were also different. The '73 model was aluminium and roughly followed the curve of the car skin, the '77 was steel and straight.
So, if you can find a later replacement I'm sure that will fix your problem.
Pete
Post by Chai » Mon 11 Jun, 2018 7:26 am
Thanks Jason.
This info means I won't spend a weekend trying to resolve this same problem with my '74 right-rear window.
Post by John Green » Mon 11 Jun, 2018 7:51 pm
Check the condition of the various nylon blocks that locate the window to the guide. You only realize how worn these are when you buy the new ones.
NZJasonT
Post by NZJasonT » Tue 12 Jun, 2018 4:28 pm
Thanks everyone for answers, Pete - looks like a 77 onwards regulator is the way to go. I wasted hours and didn’t really achieve much in the end as they still stick.
I’ll buy later model ones and update you as to how I go
Jason
1971 W108 280se 2.8
1973 W107 450 SLC
NZJasonT
Post by NZJasonT » Mon 25 Jun, 2018 8:42 pm
Pete, thank you so much
I bought a pair of 77 SLC electric window regulators on eBay shortly after your last post - they arrived today
I removed the drivers side, swapped the window motor over (3 bolts) and refitted the replacement regulator, and as you’ve said it worked perfectly first time! Your advice has saved me ( and I’m sure many others to come ) countless painful hours trying to get these rear windows to work as they should.
Anyone else out there with sticking juddering, half up half down rear windows - this is the fix right here!
Thanks Pete
Jason
1971 W108 280se 2.8
1973 W107 450 SLC
