Steering Coupling Guide SLC 450
cjhols
Post by cjhols » Fri 27 Apr, 2018 8:38 am
Hi all,
I'm after the ultimate guide for replacing the steering coupling on a SLC 450.
Peter
1973 SLC 450
1971 Clubman Mini
Re: Steering Coupling Guide SLC 450
Post by AMG » Sun 29 Apr, 2018 6:20 pm
Nothing difficult about it.
Section 46 of the factory service manual has several documents which cover various jobs. the most pertinent document relates to the jacket tube, which is not the coupling, but the main diagrams are in 46-620.
46-620.pdf
remove steering wheel.
undo the lower dash, remove carpet.
remove the floor cover plate for the steering column.
remove the coupling bolts, mark the column shaft and box shaft for the sake of alignment (steering wheel)
undo the steering colum to dash crossmember bolts and slide the column rearward.
remove coupling from steering box.
put new coupling on and finger-tighten bolt.
insert steering column spline into the coupling, refit the column to crossmember bolts. refit the cover plate. ensure the correct engagement and splines are aligned.
Tighten coupling.
Ensure the steering wheel is correctly aligned.
refit the trim pieces as required.
cjhols
Post by cjhols » Sun 29 Apr, 2018 9:16 pm
Unfortunately it might be a little more difficult than I first thought. The top of the Hex bolts have been stripped.
Hmmmm
1973 SLC 450
1971 Clubman Mini
cjhols
Post by cjhols » Sun 06 May, 2018 11:00 pm
Hi All,
Just to reassure those wanting to replace their steering coupling that it wasn't too much of a hassle. I it took me about 3 hours but most of that time was wasted under the car. Recommend tackling it from inside. You can get to both the hex bolts. Did go under the car to tighten the front hex on re-assembly. All in all made a world of difference. O'h and while I was at it I fixed the lights and stuck odometer in the instrument cluster. A good weekends work !
Peter
1973 SLC 450
1971 Clubman Mini
Post by KimB » Mon 07 May, 2018 11:29 am
Hi Peter,
Re stuck odometer, what did you do to unstick it? Normally, if the odo doesn't turn it's due to a stripped plastic gear.
I ask because both odos in my w126s aren't turning.
Kim
Post by Chai » Tue 08 May, 2018 10:15 pm
The 107 (and 116) are prone to have the odo stop working. I was told that zeroing the tripmeter while the car is moving can cause this fault.
The metal shaft for the odometer spins but the plastic rotary dial slips around that shaft.
Repair was by roughening the shaft with a pair of pliers, application of a very tiny amount of glue and forcing the plastic dial back into the shaft (plus ensuring the odometer reading is unchanged).
cjhols
Post by cjhols » Tue 08 May, 2018 11:47 pm
Yeah I probably got a little too rough with mine by "centre punching" around the end of the shaft. I found the shaft ( during re-assembly) would not go through the first cog so I had to file my work down a little. I put tape across the dials to hold them and then used a suitable drill bit to replace the shaft whilst I worked on the shaft. Make sure you measure the amount/distance of 'roughing up' that needs to be done ( the first time I didn't take into account the shaft overhang and had to re-do it / extend it.
Not a hard job - just check that your cogs / plastic screws are in good nick.
You can see if the cog is slipping - I used an electric drill, a skewer and piece of tape to turn the Odo (Anti C/W) and watched the end cog (It didn't move / slipping).
All the best
Peter
1973 SLC 450
1971 Clubman Mini
Post by Tony From West Oz » Wed 09 May, 2018 10:55 pm
The W123 series are also affected by the slipping odo shaft, resulting in an odometer that does not work. The same fix works for the W123 series also.
Post by AMG » Thu 10 May, 2018 9:42 am
The problem is widely known, and there are replacement gears available - odometergears.com had a write-up about 15 years ago or so. Not sure if it still exists, but you can buy the replacement gears you need from them.
