Charge and Maintain
nea100
Charge and Maintain
Post by nea100 » Mon 12 Sep, 2016 12:11 pm
Looking at getting a charge and maintain type charger to help keep the battery up on a W140.
Does anyone have any recommendations, was thinking of just a commonly available "Projecta" brand.
Are there any precautions I should take in leaving one connected, or could these do any damage to the W140 electronics?
Many thanks,
Col.
1984 300D - Gold, Gold, Gold
1984 280CE - Silver Blue - Undergoing minor restoration
1970 Valiant VG VIP - White - Distant relative
redlaser
Re: Charge and Maintain
Post by redlaser » Thu 15 Sep, 2016 9:29 am
I use a Projecta but I find that if the battery is below say, 11.5 volts the Projecta will take forever to charge the battery as it is a "trickle" charger only...so if your battery is older than 4 yerars old or you use the car not very often then OK to trickle charge...to permanently leave connected will do no harm to electronics unless you get a power surge on the mains!!!...the "projecta" is meant for weeks of unattended operation of a car battery.
Post by pastelgrey300D » Thu 15 Sep, 2016 12:22 pm
Highly recommend Jaycar for anything like this:
http://www.jaycar.com.au/12v-5-stage-ca ... d/p/MB3604
I also have one of their 15 amp chargers, best battery charger I've ever had. No problem charging large batteries from diesels etc. Rather than having a trickle charger I just hook this up to each car once a week on the lowest (2 amp) setting and let it charge overnight. If you keep an eye out I've seen them on sale at Jaycar for $99 every now and then.
http://www.jaycar.com.au/intelligent-6v ... r/p/MB3623
Since buying mine, I've noticed they have brought out a new model which combines the two - maybe this would be the best 'all-rounder': http://www.jaycar.com.au/12v-10a-intell ... r/p/MB3625
Post by Tony From West Oz » Thu 15 Sep, 2016 5:15 pm
pastelgrey300D wrote:Highly recommend Jaycar for anything like this:
I have a similar one - mine is 8A IIRC.
Mine of that model died after 3 years. I plugged it in, it went "CRACK" and the magic smoke leaked out of it. It didn't work anymore after that.
Post by Ivanerrol » Thu 15 Sep, 2016 8:24 pm
You can buy solar panel trickle chargers with regulators.
Just leave them on all the time.
A regulated power supply will only provide trickle or charging current when the battery needs it.
If your battery gets down to 11.5 volts then its had it.
nea100
Post by nea100 » Sat 17 Sep, 2016 11:57 am
Thanks for the replies guys. Never thought of Jaycar products David.
The solar option sounds worth looking into, great idea.
Something to help prevent having to reset stuff on an infrequently used car.
Thanks again,
Col.
Post by Ivanerrol » Sun 18 Sep, 2016 10:42 am
Here's something for all of $27.50.
Comes with a regulator
http://www.ebay.com.au/itm/10W-12V-Tric ... Sw~gRV0WnJ
