Hi all
Issue:
My power steering has gone quite hard.
After popping the bonnet, it is leaking from the cap of the power steering pump.
The fluid looked old so i replenished the fluid and the sterling still seems hard,but Better.
No other leaks.
Pump stuffed?
1972 280se 3.5 power sterling issue , leaking
- A Class
- Model you own: w114
Re: 1972 280se 3.5 power sterling issue , leaking
if it was working you might need to bleed, but I thought you did that from going lock to lock. Others will know more. Are you in the wrong forum? W108? W116 usually referred to as 350se.
- m48pro69
- Adenauer
- Model you own: w116
Yes I was thinking its posted in wrong section. :think:
