280sel finally arrives
- C Class
Hello Mercedes people.
After a nine month search I have purchased a 1980 280 sel from John Conroy in Brisbane . The car has done about 240000km and has been repainted so looks great.
It is having a few teething problems getting its blue slip in Sydney.
On some side issues...
1/ Could anyone recommend someone to 'Foam up' the slightly sagging front door trims (including reattaching of the drivers door trim)?
2/ What are people using for the maintenance of the brightwork/chromework? I have heard of autosol Metal clean. Is this good?
3/ similar question for maintenance of the internal wood panelling.
4/The front bumper has a little rust behind one of the rubbers. How should I repair this?
Thanks for your help.
Paul
Paul
- pastelgrey300D
- Maybach Exelero
Re: 280sel finally arrives
Hi Paul and congrats on the purchase!
Re: The door trims, not sure what you mean, would you be able to post some pics up?
For chrome trim and brightwork I use meguiars all metal polish, you can get it at most auto parts stores. Be very careful with other metal polishes as they can be abrasive - over time this will wear through the chrome or the very thin layer of anodising on alloy trim parts. I prefer the meguiars all metal polish as it is non abrasive and the water beads after.
Internal wood I've used plexus to clean/polish - but to remove light scratches you can use meguiars plast-x plastic polish.
How bad is the rust on the bumper? If it is just light surface rust with no chrome starting to flake off you can polish with 0000 super fine grade steel wool soaked in WD40. This will remove the surface rust - then wash down with soapy water, wipe over with a rag soaked in methylated spirits and then apply meguiars all metal polish.
1967 W111 230S - Horizontblau
1963 W110 190c - Custom Wagon Conversion (work in progress)
1983 W123 280E - About as modern as I dare to go (rolling resto project)
- C Class
I love the Meguiars range and I love the sound of beading after washing.
I will post some photos of the door trims soon so you can assess but my understanding is that there is foam??? between the door trim and door that slowly comes out as the door opens and closes over the course of time and this make the trim less volumised.
Also the thing that makes the door remain open at regulated levels is worn .Have you dealt with that?
- Giles
- 300 SL Gullwing
- Region: Western Australia
Are you referring to the door check straps.
If so I have two that may suit, about to Ebay them as I don't have a W116 any longer.
My remedy for dull bright work is Autosol in conjunction with 0000 Super Fine Steel Wool, sounds random but with some elbow grease and flannelette cloth it works a treat.
1988 V126 560SEL Poida The King wears white
1981 C107 500SLC Lola. The Queen wears black
1989 V126 420SEL Shaun The Jack wears black
2007 X164 500GL James The Joker wears black
https://www.facebook.com/kudoscc?mibextid=LQQJ4d
- C Class
Hello Giles ,
I will have a look at the car tomorrow and see if it is the door check straps .
about how much are you selling them for?
Paul
Paul
- bahnstormer109
- C 111
- Model you own: w109
- Region: Queensland
I think Paul means the foam padding inside the front door upholstery that on W116's turns to dust and then the door upholstery gets a bit baggy and loose instead of being padded.
I know the previous owner of this car and borrowed it a couple of times while my daily driver was getting fixed and drove it a fair bit. It was a good original car that has had a decent resto done on it in the past couple of years. A lot of money has been spent on it and it would be one of the best W116's around.
I hope you look after it.
Paolo
Brisbane
72 300SEL 3.5
82 380SEL
84 280CE
86 560SEL
86 230TE
89 300TE
95 E220
A good Benz these days is hard to find, so please be gentle with this Benz of mine.
Brisbane
72 300SEL 3.5
82 380SEL
84 280CE
86 560SEL
86 230TE
89 300TE
95 E220
- C Class
Guys
I am going to find out why I am not given permission to open your jpegs.
Mr bahnstormer .I imagine you are talking about V K. Thank you so much for this information.i have some receipts of the work he did and know he has spent time and money on the car .I bought it for this reason and am going to enjoy keeping it original and in good condition. Do you know who did the respray? It seems such a lovely job .
Paul
Paul
- C Class
And suddenly I can see the photos. Yes that is my car now living in Sydney looking splendid (to me) and yes you are correct I am talking about the foam that turns to dust over the course of time. I want to repad the foam on door trims.
Giles .What do you feel is a reasonable price for the door things?
Paul
Paul
- Giles
- 300 SL Gullwing
I have two check straps you can have for $30- plus post which will be $15-.
- bahnstormer109
- C 111
Hi Paul the repaint was done by MBQ here in Brisbane, they are the MB official panel shop.
Paolo
Brisbane
72 300SEL 3.5
82 380SEL
84 280CE
86 560SEL
86 230TE
89 300TE
95 E220
Brisbane
72 300SEL 3.5
82 380SEL
84 280CE
86 560SEL
86 230TE
89 300TE
95 E220
- bahnstormer109
- C 111
The original material that padded the interior front door panels was similar to this. It has a coarse open texture to allow the air to circulate from the vents from the dash to the doors. The rear doors have a more conventional foam that doesn't tend to deteriorate. It always seems to be the front doors that disintegrate on the w116. I re-padded my old 280SEL myself years ago and it wasn't difficult.
Paolo
Brisbane
72 300SEL 3.5
82 380SEL
84 280CE
86 560SEL
86 230TE
89 300TE
95 E220
Brisbane
72 300SEL 3.5
82 380SEL
84 280CE
86 560SEL
86 230TE
89 300TE
95 E220
- C Class
That is fine and I can pay via paypal.
what information do you need?
Paul
Paul
- Giles
- 300 SL Gullwing
Can you email me gilesya@bigpond.com and let me know what your Paypal email, delivery address is and I'll send you an invoice.Paul S wrote:Giles
Paul
