Drivers side door lock fault
datzed
Post by datzed » Tue 05 Dec, 2017 10:46 am
Drivers side door lock doesn't allow you to turn the key to central lock. Passenger side works, as does the boot.
So I'm assuming the door lock mechanism is faulty. Any idea where I can get a new one apart from wreckers?
Re: Drivers side door lock fault
Post by Tony From West Oz » Tue 05 Dec, 2017 6:46 pm
If you have a healthy bank balance you could try the $tealer$hip.
Have you taken the door card off to check it out? By disconnecting linkages you should be able to identify if it is the lock or something else causing the problem.
datzed
Post by datzed » Wed 06 Dec, 2017 10:47 am
Hi Tony,
I am yet to inspect the lock which I'm hoping to do this weekend. I might also try the forum sponsor to see if they have spares. This is a bit of a PITA.
gjlockyer
Ponton
Post by gjlockyer » Thu 07 Dec, 2017 5:43 pm
Hi datzed, have you taken a door card off before? If not, before pulling it straight out, you must lift the card up to disengage the hooks on its back from the inner door panel slots. Otherwise you will either snap the hooks or rip them off the card. Major PITA. attached is a photo of the same hooks on a W124 card that I have in my garage. As I recall, a W201 door card has the hooks along the bottom and across the middle, same as the W124.
If needed, I have a door lock in good condition off a well-maintained 1988 Series 2 190E - taken off the road after rear end damage. I can also supply a key but other forum members may know if its possible to get the lock reset to match your original lock.
Gary
1955 220a (1972-80) 1961 220SEb (1980-95)
1988 190E (2008-10/14) 1988 260E (11/2014-07/15)
1990 300E 2.6 (08/2015-07/17) Current car: 1991 300E 2.6
datzed
Post by datzed » Mon 11 Dec, 2017 11:59 am
gjlockyer, thanks kindly for your advise and supplied picture (I haven't taken the door cards off before so your advise is appreciated). Once I confirm the door lock issue, I'll send you a PM about the spare you have :)
gjlockyer
Ponton
Post by gjlockyer » Mon 18 Dec, 2017 8:55 pm
i datzed,
I've tried sending a personal message twice with no success - both seem permanently stuck in my out box. Instead I'll post this and hope it's not too late to be useful.
I have removed door cards from both a W124 and a W201 and it is the same basic procedure. Pretty straight forward once you are aware of a few quirks. You may find this DIY article to be of some help - keeping in mind that this is for LHD cars and that you are unlikely to have a power seat module in the door or a massive speaker.
http://www.pelicanparts.com/techarticle ... Panels.htm
You can pry the trim pieces off with a small flat-bladed screw driver, but the risk of damage to them and the MB Tex / leather on the door card is high - particularly as the plastics have aged and become more brittle. I would recommend that you get a set of plastic trim tools - a simple set of 4 to 6 tools is all that's needed and available from any car place. Even cheaper, you could try "Banggood" on the Web- you'll find a good set for underAU$10 post free from Hong Kong. The only drawback is they could take a couple of weeks to arrive
Regards. Gary
Gary
Post by Tony From West Oz » Mon 18 Dec, 2017 10:10 pm
i datzed,
SNIP
Regards. Gary
Gary,
The messages remain in your outbox until read.
gjlockyer
Ponton
Post by gjlockyer » Tue 19 Dec, 2017 12:17 am
Thanks Tony. Have sent a few in the past but never noticed that.
Gary
Return to “W201”
