300ce 12valve or 24valve
- Dernburg Wagon
Hi guys,
I've been looking for a 300ce now for about 6 months but I haven't found a combination of colour, interior, engine that I'm happy with yet.
I see a common argument between the single cam & twin cam engine. Apart from the obvious, what's the concurrence in a forum like this?
For the six months I have been looking, there are not many cars moving irrespective of price. $2,000.00 in Brisbane or a $14,000 just not selling yet everyone is advertising them as "Rare"
Comments?
Comments?
- Dernburg Wagon
Re: 300ce 12valve or 24valve
I see replies must be being delivered by Australia Post.
......real popular forum?
- Bartman4800
- SLS AMG
- Model you own: w111
Yes
Being smug will increase the speed - not
If you do a bit of effort and search around in this forum you might find your question has been answered before.
2012 W212 E250CDI
2012 W212 E250CDI
- Dernburg Wagon
Nah wont bother here..
Heaps of other forums are full of help elsewhere as that's what a forum is all about. If I want misinformation I will Google it as you suggest!
... Nice place!
... Nice place!
In short.
The main issue with the 24v's is the electronics - the EZL and multi relay - Fuel pump relay etc.
Because these 24v engined cars were only produced for a couple of years those electronic bits are hard to find and very expensive.
Still used KE injection on the M104 engine rather than the multipoint PMS injection ignition system on later cars.
At least they didn't suffer the dreaded biodegradable wiring.
EZL's are very hard to find.
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
For what it's worth, 1 day on this forum isn't enough to cover the breadth of models, sorry if that doesn't live up to your expectations. Your chosen model has its followers but not the most popular and sounds like something you have worked out for yourself with sales figures. Although I have seen it written here by an admin that he thinks it one of his favourites and explained why. That sort of stuff exists here if you want to look for it, which if you have another read is what Bartman was suggesting and not for you to google. But you won't get him on here everyday and i think a lot of us have a life that won't see us here everyday, busy getting experience we can share back later to appreciative others. If you want to check out say Benzworld, you will probably get some quicker answers but from my experience you will also need to filter out the armchair experts that are on their computers all day ready to give you a response but rarely venture outside to get real knowledge. Good info on Benzworld too and i hope that's on your list of acceptable forums.
But doesn't sound like a problem and you've found your answers elsewhere.
- MMWA
- 450 SEL 6.9
I agree with the negatives on the 24 valve version.
I'm onto year 3 with mine now (same engine, sedan version) and have not experienced any concerns after the initial bulk load of work to bring it up to scratch. Having said that it would be lucky to do 2000km a year.
I have a spare EZL and MAS relay should they ever be required. The ones currently fitted are the same ones it rolled off the production line with though. You can find them on eBay by searching the part number, they are rarely under $600 minimum though (EZL) my mas relay I got for $50 delivered.
It's quite enjoyable, my only complaint is how much spring pressure is on the accelerator pedal in comparison to my fly by wire daily diesel mundaino, it is friggen annoying.
www.mercmad.com
- brette013
- C Class
- Model you own: w124
I've only owned my 24 valve for just over a year now and at 219000km's had to get an oil leak fixed recently as it was just getting too bad. Had that done while getting anything else in the way replaced at the same time, resulting in a large bill. Also found out when I first bought it that my rear subframe mounts were rusty and had to get that fixed as well.
The 24 valve models also have bigger brake discs and from what I've seen so far front lower control arms with a non-removable balljoint. So if a balljoint is worn, expect paying for control arms ranging from $400AUD aftermarket to $1000 genuine Mercedes. Of course, buying overseas will be cheaper just be mindful of postage. If you fit them yourself you'll save $200 a side in labour, alignment is required however. Not terribly difficult if you have a spring compressor and can remove the tight to access bolt and nut holding the balljoint in.
My electrics so far is all good, only thing electric that went wrong was the aftermarket automatic antenna unit, just sourced a new replacement from the sponsor here.
brette013
- grr
- Ponton
Hi Ivan, having needed to replace mine two to three years ago I found them quite numerous on ebay.com (USA), and found two places that rebuild them with warranty for about $500USD; one in London, the other in Florida. it seems expensive but one must consider that it will last twenty years, and let's face it how many 300CE-24s are daily drivers? Any classic means spending a few dollars that a 'normal' car wouldn't require. And they are cheap to maintain regardless of the EZL issue.Ivanerrol wrote:EZL's are very hard to find.
Also a place in Hallam,Vic. that rebuilds EZLs but at the time of my enquiring back then didn't do our model as they stated it couldn't be done. When I advised them that at least two o/s businesses can rebuild they said they would look in to it; maybe they do now?
Many people freak out Re the EZL but I found out that it's not scary at all, plug and play, and if one plans ahead (I didn't LOL) a spare can be kept handy along withe the FPR and OPR relays.
Cheers.
- AMG
- OZBENZ Admin
CraigB wrote:If you want to check out say Benzworld, you will probably get some quicker answers but from my experience you will also need to filter out the armchair experts that are on their computers all day ready to give you a response but rarely venture outside to get real knowledge.
hahahaa. Thanks Craig in a nutshell. OP seems a little arrogant for a noob.
But only to add the following from experience:
10 years ownership:
1 broken thermostat, causing partial blockage of radiator, - which resulted in the head being removed and new gasket, timing cover seal fix
(was not 100% necessary at the time, it was done as preventative)
1 water pump replaced
distributor cap, rotor, oring, backpiece, coil, leads
1 header tank
a couple of header tank caps
radiator / heater hoses, brake hoses
at least a dozen regular oil changes, 3 sets of plugs.
biennial coolant changes
2 automatic transmissions - should have only been one, but that long story covered elsewhere
which resulted in a 3 year residence in JG's workshop while waiting for hoist time, and eventually a 6 speed manual transmission swap.
Several suspension changes / upgrades / decisions / reconfigurations performed - only through a desire to experiment with handling characteristics and obtain a desired 'feel'.
several different wheel / tyre combination changes - Funny how the original factory wheel offerings seem to find their way back on the vehicle... not through lack of trying others though....
Headwork was done when it was pulled for the gasket, incl a 'shave' to bump compression to just under 12:1
All in all, The car is quite cheap to run, goes like clockwork, gives no grief, and is lovingly cared for.
Most people who encounter problems with the 24v engine cars are those who buy someone elses problems.
I will say that the later HFM cars are decidedly more troublesome, due to the 'bio-harness' and this can cause any number of issues, ranging from minor component replacements to full-on 'replace everything electrical' in the engine bay.
Mechanically, I think the earlier m103 is simpler, and more cost-effective to own. the M104 is certainly robust, extremely powerful for a 3 Litre engine, and unlike the m103, has a power delivery that encourages you to really rev it out. The aural experience on an M104 is definitely one of the highlights of owning one.
If I had my time again, I think I would have bought a 124 coupe or cabriolet in preference to the R107. However, the C107 has a special place in my heart, as it was a true GT coupe. beautiful timeless styling, a lovely revvy v8 and 4 speed auto with nice positive shifts and a great engine note, but above all, a beautiful compliant ride.
Something the 124 does 'just a little differently'. Not better, not worse, just not the same.
I know deep down, that the AMG Hammer was always the car I wanted, so it's no surprise I have a coupe bias.
But the operating costs - I think it 100% comes down to how a vehicle is treated. If you look after it, then there should be no surprise that there will be some occasional maintenance costs which are a little higher than you anticipate. It's the same with every car though. 12 valve or 24 valve, the answer is not in ownership costs, but if that is a factor because of purchase budget or ongoing ownership concerns, then there is a slight advantage to the 12v M103 engine, simply because it was produced in far larger volume, so parts are more readily available.
The only other real decision is bodystyling - series 1, 2 or 3. I prefer the pronounced chrome grille surround of series 2, with the side-cladding. I'm not a fan of the series 3 bonnet and headlights. That's just me. It's not a reflection on the car.
The only thing I would be wary of is a HFM engined vehicle without evidence of a good service history.
The 5 speed auto is not an issue for sedans as much as it is for the coupe owners. It's also very easy and relatively straightforward to rectify, and once it's done (properly) then it's not an issue. but it can cost a bit if you're not mechanically minded.
Most of us are sensible enough to enlist the assistance of professionals when it comes time for major sub-assembly overhauls, and to that extent, any extensive engine, transmission or differential/driveline work should really be undertaken by a specialist independent MB professional workshop.
107.048 722.313 Signalrot Stella
124.051 716.62 Perlblau / Iceblau Gretel
201.034 717.404 Blauschwarz Hermann
212.074 722.931 Diamantweiß Klaus
124.090 722.358 Malachit Grün Beatrix
126.039 Anthracitgrau "Schultz" - In Mercedes Heaven
201.029 Signalrot "Sabine" - has taken ownership of Andrew's Garage
107.023 Astralsilber "Lurch" - now in the loving care of Craig B
201.035 Blauschwarz (parted) formerly owned by Derek/Hasan.
Can't emphasis enough the need to really trawl through the internet for bits.
I bought my W202 at a cheap price because the P.O. had been quoted $3,800 + GST for a new ECU.
I checked the Russian site, found the equivalent updated unit part number and found out the Sprinter was equipped with the newer ECU - sourced one in Oz for $175.00
However $500+ for a 24v EZL versus $50.00 for a 12v. for a car that's only worth a couple of thousand :whistle:
In Australia W124's are daily drivers - they are cheap and if you fix it yourself are cheap D.D.'s
Having said that :dance: . Wife is pushing me for an up to date car. Mindful of the depreciation I'm looking through 2005 to 2012 cars. These cars are Daimler Chrysler era design :wall:
Nephew bought a 2007 CLK with a M272 engine. After six months of ownership a Check engine light has turned up - fault codes indicate its the dreaded balance shaft issue - a minor mega thousand dollar fix.
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
- AMG
- OZBENZ Admin
Les, Not sure if you're a 204 fan, but the last of them are well enough spec'd for a shopping trolley ;)
Just missed a 2011 204 wagon with just over 40k's on it for less than $25K - procrastination :color:AMG wrote:Les, Not sure if you're a 204 fan, but the last of them are well enough spec'd for a shopping trolley ;)
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
- grr
- Ponton
Ivan, I was referring to 300CE-24 only as mostly not being daily drivers, at least the good ones :dance: .Ivanerrol wrote:...In Australia W124's are daily drivers...
Cheers.
- AMG
- OZBENZ Admin
Bloody hell that's cheap. :Doh:Ivanerrol wrote:Just missed a 2011 204 wagon with just over 40k's on it for less than $25K - procrastination :color:AMG wrote:Les, Not sure if you're a 204 fan, but the last of them are well enough spec'd for a shopping trolley ;)
AMG wrote:Bloody hell that's cheap. :Doh:Ivanerrol wrote:Just missed a 2011 204 wagon with just over 40k's on it for less than $25K - procrastination :color:AMG wrote:Les, Not sure if you're a 204 fan, but the last of them are well enough spec'd for a shopping trolley ;)
Rather than keep hijacking this W124 thread, I started a new one
viewtopic.php?f=25&t=23954
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
If I had a good CE I'd be using it as a daily driver - these cars need to be driven.grr wrote:Ivan, I was referring to 300CE-24 only as mostly not being daily drivers, at least the good ones :dance: .Ivanerrol wrote:...In Australia W124's are daily drivers...
Cheers.
Having owned a few KE cars I.M.H.O. I'm no longer in favour of them - there's too many individual expensive parts to the system - all now getting too old.
If you find a good car then it's only worth doing a Merc Mad W.A. Replace all the critical KE components with brand new ones. This also valid for 12v cars.
Expensive exercise but well worth it overall.
Either that or buy a last series car and make sure the wiring harness and throttle body is changed.
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
- john_1066
Until recently my CE was a Daily Driver, however I have bought it an assistant (a Renault Clio RS200 which offers a somewhat different driving experience). The Mercedes is still often used to go the the supermarket, which fortunately is in the next town. Here is a photo taken on the way to the supermarket.
- Tony From West Oz
- OZBENZ moderator
At first glance that looks like you are traveling fast, but then the Star would not be blurred. It looks, to me, like you went over some rough road while taking the shot. Unless you suffer from Parkinsons or the DTs (LOL)
'86 W124 300D sold
'99 W202 C250 Turbodiesel
'98 W202 C250 Turbodiesel
'86 W124 300D sold
- john_1066
No, the camera was on a tripod, but with Image Stabilisation turned on, which it shouldn't have been, so the camera was overcorrecting. The blurred scenery, and the star for that matter are a function of the exposure time of course. But this is an MB forum, not an Olympus forum. Here is one with IS off, if you prefer.Tony From West Oz wrote:At first glance that looks like you are traveling fast, but then the Star would not be blurred. It looks, to me, like you went over some rough road while taking the shot. Unless you suffer from Parkinsons or the DTs (LOL)
- brette013
- C Class
Your coupe looks like its gonna go back to the future at that rate of speed!
brette013
- Tony From West Oz
- OZBENZ moderator
John,john_1066 wrote:No, the camera was on a tripod, but with Image Stabilisation turned on, which it shouldn't have been, so the camera was overcorrecting. The blurred scenery, and the star for that matter are a function of the exposure time of course. But this is an MB forum, not an Olympus forum. Here is one with IS off, if you prefer.Tony From West Oz wrote:At first glance that looks like you are traveling fast, but then the Star would not be blurred. It looks, to me, like you went over some rough road while taking the shot. Unless you suffer from Parkinsons or the DTs (LOL)
That shot is better.
Yes the exposure has caused the impression of traveling at high speed.
'86 W124 300D sold
'86 W124 300D sold
- john_1066
Thanks Tony, yes I should have gone with that one first up. Shaky vs slightly out of focus. Tough decision. And to brette013, unfortunately the flux capacitor is buggered, another difficult part to source for this model.Tony From West Oz wrote:John,john_1066 wrote:No, the camera was on a tripod, but with Image Stabilisation turned on, which it shouldn't have been, so the camera was overcorrecting. The blurred scenery, and the star for that matter are a function of the exposure time of course. But this is an MB forum, not an Olympus forum. Here is one with IS off, if you prefer.Tony From West Oz wrote:At first glance that looks like you are traveling fast, but then the Star would not be blurred. It looks, to me, like you went over some rough road while taking the shot. Unless you suffer from Parkinsons or the DTs (LOL)
- grr
- Ponton
I would like to drive mine more, not every day though, at least a few times a week, but with our current driveway configuration it's difficult to do; to get it out I need to move the wife's W203, hitch my tandem trailer to my ute and move that as well, and then do this in reverse after I drive it Not convenient at all.Ivanerrol wrote:If I had a good CE I'd be using it as a daily driver - these cars need to be driven.
And that is the main reason I've decided to sell it.
- MMWA
- 450 SEL 6.9
I must be getting old too like the components, now that I've fixed everything I've lost interest in the car and don't even drive it anymore. I guess I was more interested in the challenge than the end game. I will find something else newer to mentally stimulate me eventually, this year hopefully.Ivanerrol wrote: Having owned a few KE cars I.M.H.O. I'm no longer in favour of them - there's too many individual expensive parts to the system - all now getting too old.
www.mercmad.com
- C Class
- Model you own: w201
My 300ce m103 is sublime...
It was almost perfect when it was released in the 80's... at the time the w124 was considered one of the best engineered cars in the world... and it is one of the easiest cars to own... just sit in it and drive anywhere and you will feel relaxed when you arrive. When I bought it the original owner who was in his early 90's had stopped driving and I bought it after a 20 minute inspection because it was that good.
I spend way too much maintaining it; and it has only ever let me down once when the accelerator cable snapped.
It is very hard to find a good one I would guess that the one's you are seeing online are NOT good cars an that is why they are not selling.
I wouldn't even think of selling mine at less than 25k... i have probably spent about 1.5k per year on average over the last 8 years maintaining it... so that alone is probably close to 12k that it owes me...
Be aware of rust too... a lot of them are not being stored well enough to avoid the problem... I think a lot of owners should be considering proactively replacing the rubber seals around windows just to future proof the cars.
w201 D2.5 315k, E2.6 205k
W124 300ce 185k
W124 300D 325k
w126 560sec 200k
w108 3.5 170k miles
r107 350SL
W124 300ce 185k
W124 300D 325k
w126 560sec 200k
w108 3.5 170k miles
r107 350SL
- Region: EU- Northern
Do you have a write up of the 300ce manual transmission swap. I searched this forum and could not find one.AMG wrote: ↑Mon 15 May, 2017 5:08 pm
10 years ownership:
1 header tank
- AMG
- OZBENZ Admin
The 5 speed manual swap is straightforward. It's all available as factory parts, and needs no write-up. Anyone contemplating a conversion should have a factory service manual and access to the EPC / WIS long before undertaking the task and as a result should have the how-to knowledge and everything required for the conversion at-hand.
I put a 6 speed in, which differs to the factory 5 speed manual boxes.
There is far too much expense and detail involved to extrapolate on how 'easy' the 6 speed manual swap is. In essence it is straightforward, but it isn't easy. I would not undertake the task again.
Nor am I willing to entertain discussing the relative merits. I performed the conversion for my own whimsical desire and to prove to a certain group of my close friends how easy it could be done, and how much time it took.
Suffice to say, 90% is bolt in, if you know what you are doing... the other 10% costs as much as reconditioning a 722.5 auto. In which case, if an owner has an issue with the 5 speed auto, I recommend an owner rebuild the auto as it will be cheaper than converting the car to a manual- for starters, you're not going to get a factory manual box cheap in this country, let alone find one available... nor will you have the correct ratio LSD, halfshafts, transmission crossmember and mounts, driveshafts, speedometer etc etc etc.
Like I said, it was an exercise in technical knowledge and proving it could be done. It provides an extra gear, and that is the extent of it. A more fun 'swap' would be a 722.6 auto with Ole's standalone TCU, and altogether it would be a much easier conversion. Not to mention the fun to be had programming the shift parameters and the ability to have a paddleshifter on the steering wheel. However tansmission swaps are completely off the topic of discussion.
