by 1973_280E » Mon Dec 26, 2005 1:04 am
I'm at the tail end of a full engine reconditioning process for my w114 280E M110. Going through the engine testing phase we have found the fuel to be a bit lean. The 280E has 2 fuel regulators from what I can gather (one for in flow and one for out flow), making it difficult to tune the fuel pressure correctly.
I find that all the manuals available to me go out of their way to avoid the 280E fuel and injection system... so annoying!
Has anyone else had a similar experience in adjusting fuel pressure on this engine model? Anyone have some data on seting the pressure between the two regulators?
1973_280E
- A Class
by OzBenzHead » Wed Dec 28, 2005 12:11 am
G'day, 280E
Might be worth trawling through this manual:
http://handbook.w116.org/.
Sure, it's for the W116 mostly, but it covers the M110 with both D-Jetronic and K-Jetronic systems.
Good luck.
OzBenzHeadNumerous Benzes
OzBenzHead
- OZBENZ moderator
by Nutz » Fri Dec 30, 2005 8:55 pm
1973_280E wrote:I'm at the tail end of a full engine reconditioning process for my w114 280E M110. Going through the engine testing phase we have found the fuel to be a bit lean. The 280E has 2 fuel regulators from what I can gather (one for in flow and one for out flow), making it difficult to tune the fuel pressure correctly.
Set it at 30 psi ( 2 bar)
The regulator is adjustable from 28 psi to 32 psi and if you can't achieve this,replace. Good luck
Nutz on Sat Dec 31, 2005 6:56 am, edited 1 time in total.
Nutz
- E Class
by Nutz » Sat Dec 31, 2005 6:57 am
OzBenzHead wrote:G'day, Nutz!
Good to "see" you over here! Long way from Alaska!
Thanks for the welcome
Lurking was sort of boring
Nutz
- E Class
by ADow » Sat Dec 31, 2005 8:01 pm
Great collection - how do you keep them out of the weather?
Alastair
1971 280SE 3.5 - Don Ottavio
1980 300D (formerly daughter's) - Heidi
1981 300D (son's) - Hektor
1998 Puma Clubman with 225 RWKW SR20DET - Percy
ADow
- OZBENZ moderator
by Nutz » Sun Jan 01, 2006 11:14 pm
ADow wrote:Great collection - how do you keep them out of the weather?
3 of my W116's are stuffed in my garage,the rest except my 6.9 (heated storage)are dealing with the elements.
Nutz
- E Class
by 1973_280E » Mon Jan 02, 2006 6:20 am
Thanks for the tips guys. I'll have to take it in to my mechanic again as I don't have the appropriate tools for checking the pressure.
Further to my previous explanation on the symptoms, the fuel pressure seems fine on starup. It's only once the engine has warmed up that the idle gets 'bumpy' and it starts to die on me.
Nutz, I assume the regulator pressure you mentioned refers to the one leading into the engine. Any ideas on what the one coming out of the engine is for (on the fuel return line, lower in the engine bay)? And what the effects of adjustments to this are?
1973_280E
- A Class
by Nutz » Tue Jan 03, 2006 2:12 pm
Do you have a photo of the area on your M110? I haven't seen a D Jet setup on a M110 yet.Going by the setup on my M117's,the feed line goes to the first regulator then to the second one.I have no regulator on the return line,so I'm a bit confused
Nutz
- E Class
by 1973_280E » Wed Jan 04, 2006 10:06 am
I'll have a look around for photos and get back to you. I took many photos during the engine dismantling stage.
I'm sure I've got a clear pic of it somewhere.
1973_280E
- A Class
by 1973_280E » Sat Jan 14, 2006 6:21 am
I managed to find a decent photo of the fuel setup. The green arrows show the fuel lines coming in and the red ones show the fuel exiting to the return line.
I can't find this setup in either the w114 or the w116 manuals
1973_280E
- A Class
by O319-coach » Mon Jan 16, 2006 1:00 pm
Top one is the fuel regulator. Lower one is a damper.
You check the pressure by taking the line of the cold start injector and testing with the engine running.
Independent importer of discounted genuine Mercedes-Benz parts.
Restorer of Concours winning cars.
Sponsor of this forum.
http://www.mbspares.com.au Toll free phone 1300 787 300
O319-coach
- Mercedes Guru/Admin
by 1973_280E » Wed Jan 18, 2006 3:15 pm
Thanks O319-coach. As Nutz kindly mentioned, the fuel regulator should be set at 30psi. Just for clarification, does the damper require some tweaking for setting the pressure as well? If so, what are the settings for the damper?
1973_280E
- A Class
by O319-coach » Wed Jan 18, 2006 4:15 pm
30psi?? Are you working on an English car? Adjust to 2.0 bar.
The fuel damper is not adjustable.
O319-coach
by 1973_280E » Fri Jan 20, 2006 6:54 am
Thanks John.
1973_280E
- A Class
Return to W114 and W115
Who is online
Users browsing this forum: No registered users and 1 guest
