My 1999 CLK320's battery goes flat after a few days being parked.
I thought the battery might have been on its way as it was more than four years old
So I bought a new battery and it's still doing the same.
Two days and it's dead as a door knob.
I called the electrician who checked it right through.
The battery is in excellent condition and there are no leaks in the car.
He reckons the alternator might have a faulty diode or two and thus is draining the power from the battery after being stopped for a day or so.
Any one encountered that problem?
Battery Drain
- Michel
- C 111
- Model you own: w116
Battery Drain
Michel (in Sydney)
W116: 1978 690SEL # 3312
R107: 1985 500SL AMG - LHD
A208: 1999 CLK320 Convertible
C208: 2000 CLK430 Coupe
- Tony From West Oz
- OZBENZ moderator
- Model you own: w202
Re: Battery Drain
If the Auto 'leccy said there were no "leaks" in the car, I presume that he meant that there was no current draw from the battery with the engine off. That would be apart from any radio memory, body computer, etc, etc currents. There should definitely be no current drawn by the alternator.
If the alternator had faulty diodes causing the battery to go flat, then this should have been tested by the 'leccy and eliminated, or confirmed, as the cause.
If there were faulty circuit diodes then the charging current would be low.
To test this with your limited facilities, (hopefully you have a multimeter) check the battery voltage with the engine at idle and the lights, A/C, fan and rear demister on. You should have more than 12V for a good battery.
Increase the engine RPM to 2K or more.
The battery voltage should rise to 13.6v or higher. Normally it should not rise above 14.5V unless you are in an extremely cold area.
If not, then go to a different Auto 'leccy.
I hope this helps,
I hope this helps,
- Finnie
- Model you own: w126
Re: Battery Drain
U must have a battery drain somewhere...disconnect the battery positive lead and connect an ammeter in series..there shud be less than 30Ma drain current (10-15ma is usual)...for an overview, read the excellent article on battery "parasitics" below:
http://www.diagnosticnews.com/parasitic-battery-drains/
- 300 SLR
Re: Battery Drain
We had the same problem in both our 300SE's. In both cases it was the car alarm draining the battery. After it was disconnected the batteries were fine.
Kim
Kim
- T-Modell
- SLS AMG
- Model you own: w107
Re: Battery Drain
I'm not joking now: Climb in the trunk, see if the light goes off. Are the indoor lights permanently on by accident? Happened to me with the W111
- AMG
- OZBENZ Admin
- Region: New South Wales
Re: Battery Drain
Just remember to make sure you don't lock yourself in there....T-Modell wrote:I'm not joking now: Climb in the trunk, see if the light goes off. Are the indoor lights permanently on by accident? Happened to me with the W111![]()
- Dernburg Wagon
Re: Battery Drain
I can only agree with the comments posted:
"You must have a battery drain"
"The car alarm" These have caused me to pay for far too many batteries (now over 10). Now I just disconnect the terminals. A pain but your battery will last for 10 years. I generally don't park my cars in areas where they are likely to be stolen so the alarms are a pain in the ass. If you drive the car every day no problem, if you have a selection put the right size spanner in the car and just disconnect.
Hope this helps.
John
Hope this helps.
John
79 450 SEL 6.9 (115k's)
79 450 SEL 6.9
88 560 SEC
89 Ducati 906 Paso (30k's)
92 300CE-24 Sportline
98 MX-5
01 CLK320
79 450 SEL 6.9
88 560 SEC
98 MX-5
01 CLK320
- 300 SLR
Re: Battery Drain
Just a side note to the alarm. Although we had alarms in our 3 w126 cars, we never bothered to activate them.john6007 wrote:I can only agree with the comments posted:
Hope this helps.
John
They were all fitted by the prev owners. The only precaution I take when leaving the car parked is to open the glove box.
This shows that there is nothing of value there.
To prove my point, we parked in a city car park many years ago. 12 cars that were parked alongside ours were broken into and ours was left untouched.
The only thing we did with the alarms was to rip them out when they started to drain the battery.
