W114 CHARGING FROM CIGARETTE LIGHTER
thirstymerc
Post by thirstymerc » Thu 07 Sep, 2017 6:08 pm
Howdy all,
Quick question.
Anyone had any luck running a standard charger from the cigarette lighter?
The lighter is heating up when pushed in, so unit works, but not getting any charge from it with a standard lighter plug to power my phone.
Could there be a voltage difference issue?
Any advice is appreciated
Steve
Chai
Re: W114 CHARGING FROM CIGARETTE LIGHTER
Post by Chai » Thu 07 Sep, 2017 9:06 pm
Is there a fuse on the lighter plug that you pushed in?
A blown internal fuse is only reason that I can think of for it not supplying power to the phone.
Did you cross check with another lighter plug attachment?
Chai
1974 450SLC
thirstymerc
Post by thirstymerc » Mon 11 Sep, 2017 11:53 am
Thanks for the response Chai.
I checked the fuse which was fine, but haven't looked for an internal one, so will have a good look at that and see if there lies the problem.
Steve
Steve
Djenka018
Post by Djenka018 » Tue 12 Sep, 2017 7:57 pm
"The lighter is heating up when pushed in, so unit works, but not getting any charge from it with a standard lighter plug to power my phone."
Early units may be a bit wider and the + terminal inside may be recessed so the charger cannot touch it.
'80 450SLC 3-continental
Post by Tony From West Oz » Wed 13 Sep, 2017 12:32 am
Have you tried the charging adapter on another vehicle?
Does it work there?
zohar
Post by zohar » Mon 25 Sep, 2017 10:45 pm
Funny as I just had the very same issue/question. My 1974 280 will not operate any USB charger, even though the lighter works. I suspect the negative tabs are too short to reach the side contacts and I will try and change the socket so that the entire shaft is negative.
I'll post my results.
thirstymerc
Post by thirstymerc » Tue 26 Sep, 2017 10:20 am
Glad I'm not the only one! Agree. I'm thinking it might be something to do with the length of the charger plug not reaching the connector points in the lighter socket also. I have tried the charger in our other car and works fine.
Let me know how you go Zohar.
Cheers guys
Steve
zohar
Post by zohar » Mon 05 Feb, 2018 1:45 am
Ended up replacing for a lighter socket the while looking the same was a bit shorter and had a smaller diameter.
on the plus side charging now works
down side my lighter wont fit anymore
Post by Tony From West Oz » Mon 05 Feb, 2018 4:04 am
Good reason to quit smoking!
Return to “W114 and W115”
