1974 W114 Brake Booster vacuum hose
zohar
Post by zohar » Sat 29 Apr, 2017 8:16 pm
Hi ,
I need to replace the (originally) translucent plastic vacuum hose providing vacuum to the brake booster. The end near the engine is leaking and crumbling.
Anyone has access to the parts catalogue to identify the part number ?
Are the especially long on RHD cars ?
Can not find it online for some reason.
Any help much appreciated.
Z
Re: 1974 W114 Brake Booster vacuum hose
Post by Giles » Sat 29 Apr, 2017 8:42 pm
They are much longer on RHD cars.
I should have a few if you can't find a new one.
zohar
Post by zohar » Sat 29 Apr, 2017 8:44 pm
Thanks Giles!
zohar
Post by zohar » Sat 29 Apr, 2017 10:27 pm
Though there should be a way to get a new one ?
Post by John Green » Sat 29 Apr, 2017 10:56 pm
A114 430 12 29, Mb don't stock it any longer. I have a used one if Giles doesn't.
Post by Tony From West Oz » Sat 29 Apr, 2017 11:45 pm
Thinking outside of the square:
Translucent nylon(?) air line (as used in trucks, etc) is available in a similar size and could be installed with the original metal end fittings.
Check out places which specialise in air lines and fittings.
Post by Bartman4800 » Mon 01 May, 2017 9:09 pm
Really anything works if it fits properly.
The vacuum is so little that it won't flatten even a garden hose.
zohar
Post by zohar » Sat 20 May, 2017 3:56 pm
Bought a length of matching size vacuum hose ( 10x12 mm) and cooked a new hose.
Return to “W114 and W115”
