Will a M119 fit a W107
Model 107 Specific Mods -
TargaSL
Maybach
Model you own: R230
Post by TargaSL » Mon 23 Nov, 2009 3:47 pm
Does anyone know this exactly
I am getting conflicting opinions
the main issue is the width of the quad cam heads
can anyone measure their M119 and let me know exactly how wide the motor is?
thanks
PR
1980 W107 - Der Panzervagen
2003 R230 - Glamour
2011 W164 - AMG Diesel
Escape the Nanny State
Race a Classic
Fotografa
Re: Will a M119 fit a W107
Post by Fotografa » Mon 23 Nov, 2009 4:20 pm
1981 500SLC 040 Black on Black leather
10702612002624
Children that have left home:
1973 R107 450SL Icon Gold
1974 C107 450SLC Black
1971 W114 230 Arctic White
1974 W114 280E Signal red
1981 W123 280E Signal red
1974 W114 280CE Silver
1975 W114 280CE Metallic Red
Post by AMG » Wed 25 Nov, 2009 11:37 am
Paul, I've heard rumours that despite fitting, the block itself is not much different to m117 560/420/500, and that may be of concern to you after the last one thew a leg out.
I would rather hear from John or someone who's had a 119 fully apart to define the differences clearly. I have heard the bottom end is almost 'indestructable' but then again the 117 is allegedly so as well.
Fotografa
Post by Fotografa » Wed 25 Nov, 2009 1:15 pm
I think despite Paul's little 'problem' it is still safe to say that the M117 block itself is strong enough for the task. I was under the impression that it was an issue of not getting enough power.
If Sauber were able to do what they did with both the M117 and M119 in the C9 I don't think reliability is as big an issue as Paul's exploding block might indicate.
I can't imagine that Paul would be pushing harder than Sauber did at Le Mans over 24 hours.
247mph is a pretty awesome top speed for an M119 powered car.
10702612002624
TargaSL
Maybach
Model you own: R230
Post by TargaSL » Wed 25 Nov, 2009 2:40 pm
One of the major reasons i believe that the engine lunched itself was that i limped it home for over a day with failing oil pressure
Though i have also broken the original 380 that the car came with (which was why the 5.5 went in)
If i had a sponsor it would be no drama to experiment with a 117
if you have seen the list of mods i put up a while ago they are extensive but achievable
the issue for me is now that after i get used to reliable 500hp + going back to circa 300 and spending a lot of $ doing that and stressing about how brittle it is has got me worried
The answer seems to boost it somehow but the issue of fuel balance especially at sustained high revs is a real drama that can only be solved by electronic metering (Motec etc)
we believe these mods which should make the engine sustainable over several days of punishment but it looks like a $30k exercise and most likely needs to get stripped down after about 3-5 K racing miles (every year)
I don't have the budget for that, but if i find a sponsor it becomes feasible
In the meantime the MerChevy should be firing up next week
2003 R230 - Glamour
Race a Classic
Post by AMG » Thu 26 Nov, 2009 8:00 am
Paul, I'll email you with some info.
Return to “107 Mods”
