ELECTRONIC IGNITION SWITCH
Mickey
Model you own: w164
Post by Mickey » Thu 01 Sep, 2016 3:43 pm
Last week an intermittent fault started. I would turn the key in the ignition and nothing would happen. No dash lights, no steering wheel moving, no engine cranking. Turning the key on and off a few times would get it working and everything would be OK again.
I presume the culprit will be a faulty electronic ignition switch (EIS) as the it doesn't matter which key I use and I have a new car battery and key batteries. The car unlocks fine with the key remote and there do not appear to be any other issues. If it is the EIS, is this something that could be a do-it-yourself item to replace or does it need dealer programming into the car's main computer or to be made compatible with the key codes?
Technology is great when it is working.
Re: ELECTRONIC IGNITION SWITCH
Post by Tony From West Oz » Thu 01 Sep, 2016 6:00 pm
Replacement of the ignition switch does require the use of a 'master key' (for the want of a better description) and for it to be paired with the ECU. I have had this done at my independent Mercedes specialist. You should check if your inide. can do it or if you need to go to the $tealer$hip to get it done.
Did you pull the key out each time you tried it or was it still in the lock? I had an issue (much later than the above replacement) where the little door over the key opening was stuck open. The key would not unlock the steering or do anything. Once the little door was closed, all worked properly. It was lightly lubed and has not had the problem since.
mattml430b
Model you own: w163
Post by mattml430b » Thu 01 Sep, 2016 9:06 pm
The key sink is around the outside of the ignition switch and can be removed separately. The ignition switch is more mechanical so to speak.
Sorry is this a W163. ML
Mickey
Model you own: w164
Post by Mickey » Fri 02 Sep, 2016 12:44 pm
It didn't matter if I pulled the key out or not, the fault was still there. I even cleaned the key socket. Looks like a trip to the stealership if programming is needed. Thanks for the input and photos.
