air in fuel ml270 not starting
rolfson66
Model you own: w163
Post by rolfson66 » Wed 01 Apr, 2015 8:58 pm
hi just wondering?? I have replaced all o rings in fuel lines.new lift pump non return valve fitted before new fuel filter and I still have air in fuel lines. as soon as I turn off it will not start again unless I use airo start,when running I can see air in fuel line coming from fuel filter? can anyone help?? love the car even with its little probs Thanks Rolf
Re: air in fuel ml270 not starting
Post by Tony From West Oz » Wed 01 Apr, 2015 10:56 pm
Try replacing the O rings of the bolt that secures the filter to the housing.
rolfson66
Model you own: w163
Post by rolfson66 » Thu 02 Apr, 2015 9:25 am
just had a look at fuel filter, mine is a sealed unit with intake and outlet at the top, the whole unit sits in a cradle with a bolt on the side to secure in place,i couldn't see where another o ring could go?
Thanks Rolf
Post by Tony From West Oz » Thu 02 Apr, 2015 4:12 pm
OK, then it is different to other Mercedes diesel filters I have seen.
Someone else may be of some help to you.
