HI Guys
Does anyone know if the timing is adjustable on a 1988 230 te with 4zyl printed on the ecu. Its running way advanced I retarded the dizzy to its max but it still 2 deg below tdc when it should read 10 deg btdc.
Any ideas would be appreciated.
230te Timing
- C Class
- Model you own: w126
- C Class
Problem solved
The timing isn't adjustable from the Dizzy. but found the problem.
See other post
See other post
