Some detailing tips
Some detailing tips
Post by AndrewsSL/SEL » Sat 14 Sep, 2013 10:28 am
I spent some time this morning watching a few interesting detailing videos.
How to touch up paint chips!
http://www.youtube.com/watch?v=6xi3xmeO6C4
Cleaning your engine
http://www.youtube.com/watch?v=LESRJrB1L5I
Cleaning wheels
http://www.youtube.com/watch?v=UOMNFb8k ... F54166C886
Cleaning up a barn find Porsche 912
http://www.youtube.com/watch?v=Q3Mz6YNb4uA
Re: Some detailing tips
Post by markb » Sat 14 Sep, 2013 12:00 pm
Loved the 912 video...Great find Andrew
Post by cuisses » Tue 24 Sep, 2013 10:51 pm
The touch up video is great. Over the past few days I used the techniques they suggest to touch up a rather large crater in the paintwork which was left there by a mechanic ( not an MB Spares one, I should point out), who must have dropped a largish spanner on the Benz. It was right through to bare metal, (and on my resprayed car the paint is very thick), and about 3 mm across.
After repair I can still see a slight defect, but that is because I know exactly where it is. Nobody else would notice it.
The only differences between the video and what I did are as follows:
(1) I couldn't get the "touch up" sticks he mentions, except by paying a fortune to Amazon. I used a tiny pointed brush from an art store - seemed to work just as well. You can get them with tips like a toothpick.
(2) The wax trick is great, but it seemed to be easier, at least for a large hole, to paint around the hole with wax, rather than paint wax everywhere and then remove it with alcohol.
(3) As well as mixing clear-coat with the paint (as explained in the video), I put a couple of coats of clear on top of the finished job, spraying it over a masked-off area of about 2cm by 2cm and then sanding the sharp edges into the background.
I had tried to fix chips before, without knowing what I was doing, and ended up with the kind of look you might expect.
Using the video method produces great results. Skill is not important here, but patience certainly is.
Return to “Exterior”
