W211 E320 CDI Vibration
PunkJr
Post by PunkJr » Fri 19 Jan, 2018 9:25 pm
Hello all
My 2008 has developed a slight vibration, felt through the wheel, at cruising speed. At low speed on a smooth road I can hear a rythmic knock, but I can only hear this occasionally. I first noticed this after hitting a large pothole at cruising speed. It hit hard. I took the car to my local mechanic and had the wheels balanced, however it has not helped. Does anyone have any clues as to what may be the cause of this?
Ty
PunkJr
Re: W211 E320 CDI Vibration
Post by PunkJr » Tue 15 May, 2018 10:54 pm
So anyone with similar symptoms, here is the end result:
I replaced both of my left hand side rims, which were bent from hitting the pothole, replaced tyres which had bad wear on the inside, had only done 15,000km, and the car is now driving as it should, with no vibration.
Post by Bartman4800 » Wed 16 May, 2018 10:57 am
So your mechanic balanced your wheels, and did not pick up the LH ones were bent?
This is a bit concerning to say the least....
Post by Tony From West Oz » Thu 17 May, 2018 1:42 am
Time to replace the.......Mechanic
methinks
