Rear Passenger Widows Issues
Grumpy
Model you own: w210
Post by Grumpy » Thu 22 Dec, 2016 8:30 pm
Howdy brains trust:
My Off side window feel into the depths of the door. I pulled the door trim off today and notice that there is cable freely hanging about. The runner thingy attached to the bottom of the window has a broken white bit and its guts in the bottom of the door. Question, are the broken bits from the attached bit pivoting from the bottom of the door part of a window regulator replacement. i will talk to the guys in Canberra tomorrow to check on availability of parts.
Also, a strange thing happened a day or two before this happened; the SRS light came on. Is there a connection????...hope all this makes sense.
Kel
The Liver is Evil & must be Punished
W210 Elegance E320
Chrysler 300C Mercedes OM642 V6 Diesel and drive line.
Departed - W201 190E
Re: Rear Passenger Widows Issues
Post by Tony From West Oz » Fri 23 Dec, 2016 1:19 am
The wires are part of the window regulator. Looks like you need a new one (I don't know how good used ones are, but the forum sponsor should be able to give an opinion on this)
The SRS light comes on if there is an issue with the SRS system (airbags). Unlikely to be related unless the wires have snagged a cable going to that door airbag actuator.
Grumpy
Model you own: w210
Post by Grumpy » Fri 23 Dec, 2016 9:27 am
Tony From West Oz wrote:The wires are part of the window regulator. Looks like you need a new one (I don't know how good used ones are, but the forum sponsor should be able to give an opinion on this)
Thanks tony, my thoughts exactly..
Kel
W210 Elegance E320
Post by Ivanerrol » Fri 23 Dec, 2016 9:36 am
Very common problem.
Buy new. Don't bother about second hand.
Grumpy
Model you own: w210
Post by Grumpy » Fri 23 Dec, 2016 8:05 pm
Ivanerrol wrote:Very common problem.
Advice appreciated...
W210 Elegance E320
