W210 Cup Holder
Pcollie64
Model you own: w210
W210 Cup Holder
Post by Pcollie64 » Sat 26 Mar, 2016 5:26 pm
HI all,
I shopped around the many Merc wreckers, letting my fingers do the walking, including our mates at MB spares and there seems to be no cup holders in Australia.
I jumped on eBay and found one for $20.00 (USD) and shipped it was $40.00 Australian dollars... I know it swings toward the driver but I'm cool with that... However, The bl%^dy thing won't pop out by itself and I cannot close the rear lid of the console where it sits.
The cup holder is seated and secure, If you open the console lid (armrest) and wiggle the cupholder, it will pop out. It pops back in ok but you can see its fowling on the back of the the console when closing.
There is no way the wood grain lid will close at all..
This poses a question..
Is there a different console?
I liked the look of these "pop out" cup holders...
Any suggestions?
Pete Collie
99 W210 E430
Re: W210 Cup Holder
Post by Ivanerrol » Tue 29 Mar, 2016 1:49 pm
The reason why there are no cup holders available for these cars is that if fluid spills down into the area around the gear selector there is a risk that an expensive ECU under there will be destroyed.
Don't under any circumstances let sugared coffee or soft drinks spill down in that area.
Even spraying the area with commercial cleaners has been known to cause issues.
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Tue 29 Mar, 2016 2:10 pm
WOW,
Well there's a great reason not to leave it in there.. :)
Bugga, I like having a coffee on long trips..
Thanks for the advice
Pete
skorneev
Model you own: w210
Re: W210 Cup Holder
Post by skorneev » Tue 05 Apr, 2016 1:31 pm
I bought a cupholder from MB Toorak 2 months ago for $50 - they had one in stock.
When installing it, I first had the same problem you're describing - it has to go all the way to the back of the tray, and then push it down until it clicks. Once I've done that, the lid started opening/closing properly, and the cupholder ejecting/retracting as it should.
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Tue 05 Apr, 2016 3:18 pm
Thanks skorneev,
I'm sure its seated right, I'll try it again when I get back form this trip.
I ripped it out and put the little plastic cup back in after the comment from Ivanerrol.. :)
I'll have another look at it when I get back.
regards
Pete
skorneev
Model you own: w210
Re: W210 Cup Holder
Post by skorneev » Wed 06 Apr, 2016 2:43 pm
Pcollie64 wrote:Thanks skorneev,
regards
Pete
See how you go Pete, if you're in inner south-east I'm happy to help - I bought a 2000 E430 a year ago, would be good to hear of your ownership experience.
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Wed 06 Apr, 2016 5:06 pm
Inner south east?
Shouldn't be that far away, I'm in the Frankston area.
I work a lot interstate, currently in Dubbo, and will be in Adelaide and Cairns next week.. Then home finally and I'll give it another go..
Maybe a coffee catch up and compare the E430's.. :)
Pete
skorneev
Model you own: w210
Re: W210 Cup Holder
Post by skorneev » Wed 13 Apr, 2016 9:44 am
Pcollie64 wrote:Inner south east?
Pete
I'm in Malvern, not too far away. Will PM you regarding the catch-up
SantoC
Re: W210 Cup Holder
Post by SantoC » Wed 15 Mar, 2017 12:30 pm
Just obtained a cup holder!
For those who are interested, part number is B66920101.
Also, included instruction pamphlet indicates they also fit W202's, CLK coupes/cabriolets.
SantoC
Re: W210 Cup Holder
Post by SantoC » Wed 15 Mar, 2017 12:35 pm
A few pics of how it looks...should you consider one.
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Wed 15 Mar, 2017 1:23 pm
Looks that same as mine...
Can you close your console lid with it in there?
SantoC
Re: W210 Cup Holder
Post by SantoC » Thu 16 Mar, 2017 1:24 pm
Pcollie64 wrote:Looks that same as mine...
Yes, but only after ensuring the cup holder guides were in their correct position - sitting flush with the recesses.
SantoC
Re: W210 Cup Holder
Post by SantoC » Thu 16 Mar, 2017 1:29 pm
Installation instructions.
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Thu 16 Mar, 2017 6:38 pm
Thanks for posting the instructions.
Mine seats and clicks into place but the door will not close over it.
Maybe I have the wrong cup holder, its a genuine part, i'll check the part number against the one one you posted.
I was beginning to think the console may be different on the Avantguard... hahaha
Pete
SantoC
Re: W210 Cup Holder
Post by SantoC » Fri 17 Mar, 2017 11:12 am
My understanding is that these cup holders were predominately for the North American market, nevertheless they fit in our W210's here in OZ.
Pcollie64 wrote:Mine seats and clicks into place but the door will not close over it.
Are you able to close the console lid if you where to remove the cup holder? Perhaps you might have something lodged in the lid's cog wheels, preventing its closure. A vacuum or an air gun might do the trick.
Is you're car the updated facelift model by any chance?
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Fri 17 Mar, 2017 11:27 am
No, its a pre facelift E430 Avantgard.
I tried removing the cup holder yesterday and while it was out I tested the lid, it opens and closes fine.
When inserting the cup holder, It slides in to the top guides and clicks into place at the base, but the console door fouls the front beveled edge of the cup holder.
I have ensured the base of the console is clean, with no obstructions. Got me stuffed.. :wall:
Pete
SantoC
Re: W210 Cup Holder
Post by SantoC » Wed 22 Mar, 2017 2:47 pm
Strange problem.
Is the console out of alignment perhaps?
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Wed 22 Mar, 2017 3:09 pm
SantoC wrote:Strange problem.
It doesn't appear to be... Everything lines up, doors open and close smoothly and there are no marks on the mounting screws indicating that have been removed at all. Its been there since 1999. :glasses2:
I had another look at it today and when I put the cup holder in, I can hear it click into place at the base, however is still sits a little loose. The holder doesn't pop out without wiggling it as it fowls on the lip at the top of the console. Now that shouldn't happen either. It appears obvious that its not seating correctly. I have tried to get it lower without any luck.
I'm tempted to mill off 1/8 of an inch from the base of the cup holder to see if it makes a difference.. I'll lose the tabs though i'm sure i'll be able to secure it down if it works. But thats a last resort.
:wall:
Re: W210 Cup Holder
Post by Tony From West Oz » Thu 23 Mar, 2017 12:05 am
Last night I watched a youtube video on replacing the console switches on a W210 https://www.youtube.com/watch?v=nmdiGzMIE9c. The poster had a similar issue and complained that the cup holder was poorly designed and the cup was held in a forward leaning angle, resulting in spills getting into the switch board under the console. His seemed to not lock down properly either.
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Thu 23 Mar, 2017 5:40 pm
Just watched that youtube video. Looks to me his cup holder is broken... It only has the one holder and the swivel pin appears to be broken.
For the record, I took off 2mm off the base, and it sat down enough to open and close the lid, but still fowled on the to[ front lip of the console. So I ripped it out, put the little plastic cup thing back in there.
Who needs a cup holder anyway :(
Thanks for all the feedback though.
Pete
Starman
540 K
Model you own: w211
Re: W210 Cup Holder
Post by Starman » Thu 23 Mar, 2017 10:16 pm
Years ago I commissioned this - one piece custom coffee holder for my W211 - solid as a rock and matched to the wood trim.
W212 E400 Avantgarde
W211 E500 Elegance sold
W202 C200 "the Tank" sold
Pcollie64
Model you own: w210
Re: W210 Cup Holder
Post by Pcollie64 » Thu 23 Mar, 2017 11:56 pm
Nice...
