Airflow meter
pschim
Model you own: R129
Airflow meter
Post by pschim » Tue 17 Feb, 2015 4:51 pm
My R129 keeps blowing air flow meters. I've fitted two 2nd hand ones now and they've both blown the electronics.
I've replaced the main wiring loom and had the throttle body electronics reconditioned as well.
I've found a more robust version available on ebay: http://www.ebay.com/itm/Mercedes-R129-S ... 1374041006
Has anyone else fitted one of these and do they work? Are they more robust than the standard cylindrical BOSCH versions? Are there any others that might be cheaper but good?
