Where is the most likely place for a leak in central locking
berntd
Model you own: w110
Post by berntd » Fri 14 Nov, 2014 8:57 am
Hello
My 230SLK central locking pump runs for a very long time when I LOCK the car.
Unlock is normal.
Where is the most likely place I should look for leaks?
Bernt
Re: Where is the most likely place for a leak in central loc
Post by Tony From West Oz » Fri 14 Nov, 2014 9:52 am
The CL Actuators are the location of most CL vacuum locking leaks.
Rarely there are joiner of pipe issues.
Joiners and Tees are under floor mats, so fault finding is relatively easy.
I hope this helps,
berntd
Model you own: w110
Post by berntd » Fri 14 Nov, 2014 2:10 pm
Thanks for that.
Just got this car last night and very excited stil :dance:
Where is the CL pump located in the SLK230?
Actuators:
Left door right door and bootlid fuel flap. Or are there hidden others?
Also, where is the battery located in this vehicle?
Bernt
Post by Tony From West Oz » Fri 14 Nov, 2014 3:33 pm
Most likely next to the spare wheel in the boot.
To troubleshoot the CL System, get a couple of golf tees and disconnect the lock hoses (Yellow / red stripe?) at each Tee or joiner to isolate the actuators in turn. When you find the faulty one, get a replacement or repair it (search for actuator repair on this forum).
Happy hunting.
berntd
Model you own: w110
Post by berntd » Fri 14 Nov, 2014 3:54 pm
It must be there somewhere but in the 'usual' place in the boot like on the sedan, I found the roof pump instead of the CL pump.
Will look into it tomorrow. Tonight, I 'll just sit in it for a bit :love10:
Djenka018
Post by Djenka018 » Fri 14 Nov, 2014 9:11 pm
The actuator that is slowest to respond could be leaking.
I think that all the cars post mid 90's have 2 way CL (vac vs. pressure).
There could be an issue with a sensor switch too.
'80 450SLC 3-continental
berntd
Model you own: w110
Post by berntd » Sat 15 Nov, 2014 10:11 am
Ok. I found it.
Driver side door actuator.
It can't disassemble but I managed to repair it anyway.
It has steel balls pressed into unused passages and the plastic around one had split.
Repaired with tiny blob of silicone. 15 year warranty. :whistle:
I still have to fiddle it all back into the door though...
Regards Bernt
