Blown Head Gasket: Replace or Repair?
- E Class
If the head gasket is blown is it a difficult job to replace? Or is it better to replace it?
1985 230e auto 4sp
- 450 SEL 6.9
- Model you own: w203
- Region: New South Wales
Re: 230te Blown Head Gasket: Replace or Repair?
Replace Head Gasket - 1hr nth you have the man for the job ...mercmad.
639 Vito
C200 Kompressor
C200 Kompressor
- julian
- M-100
- Model you own: w126
I think that the choice comes somewhat down to how much you can do yourself. Having followed some of your earlier threads you seem handy.
I would be inclined to strip everything as it is in the engine bay, and if you can then remove the head yourself. Timing chains make this job a little painful, but not impossible.
Once the head is off a close inspection might reveal a crack or significant warp, and then the decision is made, and you are already halfway there having stripped the engine bay ready for the new motor to be installed. But, if it looks clean and the block is not damaged then a 4 cylinder head rebuild wouldn't be very costly, and judging by your poor mate's description damage is likely to be minimal.
The big money for this kind of job is in the labour. Handing someone the job while you sit at home drinking beers in front of the computer (probably researching to the minutiae the job the mechanic is doing for you anyway) will end up costing plenty more.
300TD
250SE
20 year old Subaru Outback that will not quit
Peugeot 508 wagon
Previously: 1977 300D, 1979 300TD, 1982 280SE, 1988 560SEL, w123 Lang
250SE
Peugeot 508 wagon
- E Class
Thanks Julian.
1985 230e auto 4sp
- Große
remember, solve the issue that caused the problem in the first place :)
was it a bad thermostat or low coolant or a coolant leak that made the car overheat ?
- E Class
1. The fuse that controls the electromagnetic system that engages the fan to activate as it reaches running temp
1985 230e auto 4sp
- Große
The water pump could have a slow leak as well,. it's almost unnoticable.
Best way to check is to put a bunched up bit of paper towel wedged into play underneath the waterpump and let the car sit overnight. If it's got coolant on it the next morning you have a bad pump gasket and possibly waterpump itself
this is from the om617 diesel though, not sure about the petrol 2.3
- Mercmad
- Model you own: w109
It's pretty easy to work on these engines .I would say the head gasket was quite possibly due to blow and at 350,000 it has done well. If you want to do it yourself ,get ahold of a manual or scour the German websites where others have rebuilt these engines. Get the car intro a space where you can pull the head off yourself,with plenty of light ( the bonnet opens right up to give great access. ) all too often i have seen owners strip their cars down,only to find they lose interest or the working conditions are like hell on earth and they give up . Theres a few things you need to budjet for, besides fresh oil and a filter. A head gasket ,A1020162420,manifold gaskets A1021412780 &A1021421480 x 4 , a radiator check (get it flushed) , new belts and a water pump. A thermostat and spark plugs.
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
You have already spent the big bucks getting the body up to scratch. Find a garage or workshop you can rent some space and do what you can yourself. Farm out the head testing and / or reconditioning to specialists who machine and test heads. When you get it back, put it together again, confirm valve timing and repair the coolant leak.
Get a quote for the work to be done to the head. Price a replacement radiator and water pump. If you replace them both, you know that they are there for the life of the car.
ps, she looks fantastic.
'86 W124 300D sold
'99 W202 C250 Turbodiesel
'98 W202 C250 Turbodiesel
'86 W124 300D sold
- E Class
If the head needs shaving, can it be shaved or does it need to be pressed?
Do to my current circumstances I will need to find someone to do it.
Otherwise the car will rust before I get around to fixing it all properly, I'm in the middle of building a house.
I'll start to get some quotes this week for the head gasket replacement, head overhaul, thermostat, water pump etc.
1985 230e auto 4sp
- E Class
Compression test and all cylinders are at 170. Operating temperatures are stable for now at 80-100.
1985 230e auto 4sp
