Hey guys,
Ordered a replacement inner tie rod end for my 78 280CE from my local parts store, turns out to be completely different than my current tie rod end.
Its was much shorter and had a M14 Thread where mine is M16. Has anyone got a link for the correct part number or even somewhere I can check specifications?
280CE Tie Rod Ends
- E Class
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
Re: 280CE Tie Rod Ends
They should be the same as the sedan ones.
I will have a look at the EPC for the part numbers.
'86 W124 300D sold
'99 W202 C250 Turbodiesel
'98 W202 C250 Turbodiesel
'86 W124 300D sold
