Airconditioning
leoramon1952
Airconditioning
Post by leoramon1952 » Fri 25 May, 2018 10:16 am
Morning all, has anyone replaced there air con pump with one from another make of car
in my 230E everything exept the pump is ok, and the cost of such a conversion?
Started out with nothing, got most of it left
Re: Airconditioning
Post by Bartman4800 » Fri 25 May, 2018 12:08 pm
Hi, and welcome.
Do a search in the W123 subforum, and thou shalt find answers...
Re: Airconditioning
Post by John Green » Fri 25 May, 2018 8:00 pm
This is the W123 sub forum, or did someone move the topic?? Anything is possible, but you may be surprised just how much it will cost to fit a differant compressor. You will need a differant bracket, differant hoses, differant electrical connections and you have to find a compressor that uses the same style of drive belt. . If you can fabricate all of these yourself then yes it will be cheaper, but if you have to pay by the hour for any of these parts then I would suggest it is false economy. There certainly is no "off the shelve" conversion kit.
tsharkey
Re: Airconditioning
Post by tsharkey » Fri 25 May, 2018 11:43 pm
You can fit a sanden compressor with a kit but their pretty pricey - Between US$329.95 to $579.95.
https://www.klimakit.com/product/w123-s ... grade-kit/
Are the Sanden compressor that much better ?
mathuisella
Re: Airconditioning
Post by mathuisella » Mon 28 May, 2018 7:36 pm
I have a AC compressor from a 230E in my spare parts pile. It's untested bought from wreckers. applied 12v to it to see if clutch engages and it does nicely :)
Pete49
Re: Airconditioning
Post by Pete49 » Tue 29 May, 2018 3:09 pm
My mate put a sandan knockoff in his '67 Fairlane and its still going well 3 years one and my other friend put one in his '82 W126 and happy as. cost of the compressor was about $150 then needed hoses made up as his W126 had a york originally.
1978 W123 300D Maple Yellow
1983 W123 280TE Champagne
1978 W116 450SEL Silverblue
