Yellow Check Valves 280CE w123
Martyn 280CE
Post by Martyn 280CE » Wed 21 Feb, 2018 11:54 pm
Hi I used to use this forum a lot.and still have my 1984 280CE W123 - Vin Number WDB1230532A2180
I have had no issues until now...and am going to be doing a few jobs I have ben putting off.
My car failed rego For the first time in 15 Years due to seat not locking - I believe an actuator is leaking on the passenger seat.
I also noticed very quickly that the yellow vacuum valves and the six way rubber were very tired and hard while checking so I have ordered and received the today and was led to believe that al four were different.
My question is how do I know which is which of the four.
Ac / Seat Lock / Door Lock / Headlamp Adjust
Or are they actually all the same.
Thanks for your help.
Martyn
Martyn.
1984 280 CE
Sydney, North Shore.
tsharkey
Re: Yellow Check Valves 280CE w123
Post by tsharkey » Thu 22 Feb, 2018 6:09 pm
Blue for seats
Yellow for CL
Purple for Lights
Green for AC
Grey for Vacuum Gauge
Red for extra vacuum tank in LH guard
Brown for Fuel Shutoff (Diesel)
Black for Vacuum modulator related for auto trans
The two way check valves are all the same. Easy to test (on the 2 pipe side, with one blocked, does the other hold vacuum) - I have never replaced with new, simply got a box of spares off wrecks and replaced at most 2 over the years. Some have inline check valves but the seats wont, as they want to loose vacuum as soon as they can
If it is only 1 seat, it is not the valve on the doors that release the seats. So it is either the valve on the side of the seat or the actuator underneath. If it is the actuator, have to take the base pad cover off to remove the actuator. The actuator itself is generic, it is the locking mechanism it pulls that is specific to the seat.
Hope that helps.
