Depo headlights
Thunderbolt
Depo headlights
Post by Thunderbolt » Fri 26 Jan, 2018 3:33 pm
Hi all had a cracked headlight glass and rusty reflector so I bought pne of these depo headlights off fleabay for a bit over a hundred bucks. Its better than I expected but no vacuum adjust, so I pulled the actuator thing off the original and wracked it in now got vacuum adjust. All the screw mounts are already there even the vacuum pod thing where the electrical plugs in is there and holds vacuum. Its a good brihjt light with the same pattern on the glass
Re: Depo headlights
Post by Ivanerrol » Fri 26 Jan, 2018 4:40 pm
Make sure the lens is for Right hand drive.
There should be an arrow on the glass pointing to the left.
