300D starting problem
jess
Post by jess » Tue 18 Apr, 2017 7:51 pm
I am having an issue when starting my 1981 300d, i wait for glow light to go out turn key and just get a single "click" this might happen 3/4 times and then she fires up, but on other occasions she starts straight away.
Has anyone else experienced this? any help would be much appreciated.
Cheers.
Re: 300D starting problem
Post by Tony From West Oz » Wed 19 Apr, 2017 1:05 am
This sounds like a starter motor solenoid issue.
Either it has dirty contacts or is jamming, preventing the contacts closing.
The repeated attempts indicate that sometimes it is not jamming, or sometimes it makes good contact.
Some people recommend using a hammer to tap the solenoid to free a jamming solenoid armature.
jess
Post by jess » Wed 19 Apr, 2017 8:53 pm
Cheers Tony I appreciate your help.
Post by Bartman4800 » Thu 20 Apr, 2017 2:50 pm
Don't use a hammer, use the stem. Otherwise use a broomstick. You could dent the solenoid with a hammer, rendering it useless...
If you take the starter motor off, you can usually fix the solenoid by cleaning the inside (piston and bore) and putting a light lubricant on (my dad used molycote and that did not work on cold mornings)
Make sure the contacts are clean too.
GrampiansMerc
Post by GrampiansMerc » Wed 26 Apr, 2017 12:59 pm
Getting the starter motor off is a bit tricky....
Several long extensions on the 1/2inch socket set, as well as a uni joint adapter will be useful (plus a 10mm allen key head for the 1/2inch socket)
1980 300TD "Anna" - 400,000kms and still cruising, converted to SVO
1979 300D - sold, gone to be restored
1980 300D - "Lightning" recently purchased and currently making repairs
2006 Musso - Korean Mercedes, 5 cylinder diesel - Blown head gasket, buggered motor, grrrrrrr (I will stick with German Mercs)
Looking for 300GD LWB five door!
http://www.overlander300td.wordpress.com/
I'm just a simple man trying to make my way in the universe
mathuisella
Post by mathuisella » Sun 21 May, 2017 4:55 am
How did you go with this Jess ?
I had this problem recently and just replaced the starter motor itself, i still have the old starter motor here.
I am going to open it up and service the solenoid and more happy to take video and pictures.
but won't be able to do it until june 25th as i still have uni assignments and exams for the next 5 weeks.
