230E 1985 gearbox won't shift
- C Class
Hey guys,
I've recently bought my first Mercedes, a 1985 W123 230E. It came with a stack of service history but a gearbox that selects drive and reverse fine but won't shift up.
So far I've done the following
I've checked if the modulator valve holds a vacuum, it drops from around 15 down to zero in around 60 seconds, I believe this is normal?
I've disconnected the kick down switch, no difference
I've replaced a cracked breather hose that the gearbox vac line connects too, no difference
Other stuff I know
The previous owner had a local garage check the gearbox, they changed the oil and filter and reported metal swarf in the oil and therefore recommended replacement.
The central locking system has a massive leak, I'm in the process of checking this.
So, any ideas, recommendations on what to try next?
Steve
Other stuff I know
Steve
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
Re: 230E 1985 gearbox won't shift
How far did you rev the engine during your test drive. Take it to red line. Does it shift now? If so you may have a lack of vacuum getting to the modulator or a faulty modulator.
Does your central locking work properly? Is the brake booster working properly (depress brake pedal several times until the pedal gets hard. Then, while pressing the brake pedal, start the engine. The brake pedal should drop noticeably as vacuum builds up.
Note: if the vacuum take off from the main vacuum line gets blocked, you will experience vacuum related issues. Remove the vacuum spider from the vacuum take off nipple, drill out the nipple on the vacuum take off and reconnect it to the vacuum spider. If it was blocked, this should fix most of your vacuum issues.
'86 W124 300D sold
'99 W202 C250 Turbodiesel
'98 W202 C250 Turbodiesel
'86 W124 300D sold
- C Class
Thanks for the reply.
I took it to the redline tonight, it didn't change gear, my kick down switch is disconnected, not sure if this could effect it?
Brake booster is working fine, I carried out the test, the pedal dropped once the engine was started.
Are you able to post a picture showing the location of the vacuum take off nipple?
Steve
Steve
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
If it won't shift up at red line then I believe that there is something wrong inside the box.
Does your car have an "economy" gauge? That is actually a vacuum gauge and will show you the vacuum that the engine produces in the inlet manifold. At idle, or deceleration, the needle should be hard over to the left. At full acceleration it may be less than half way across the gauge.
The vacuum off-take is on the main vacuum line from the inlet manifold (or vacuum pump on diesel engine W123s) about 400mm from the brake booster. If the 'Economy' gauge works properly then you don't have an issue with the vacuum off-take.
'86 W124 300D sold
'86 W124 300D sold
- C Class
Bugger, the economy gauge is working as you describe. Time for a replacement box! Chris from MB spares reckons they have one. I'm waiting for a quote for shipping as I live in Tassie.Tony From West Oz wrote:If it won't shift up at red line then I believe that there is something wrong inside the box.
Really grateful for your help,
Steve
- C Class
Quick update. I managed to source a replacement gear box from Chris at MB spares. She's up and running now, really please. Thanks to every one who offered advice.
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
Great, now to enjoy how the car should run.
Did you fix the vacuum leaks in the CL system?
'86 W124 300D sold
'86 W124 300D sold
- C Class
Almost! I still have some small leaks which I'll aim to fix over the coming weeks :-)Tony From West Oz wrote:Great, now to enjoy how the car should run.
- AMG
- OZBENZ Admin
- Region: New South Wales
part of the fun in owning a classic - always a never-ending source of new things to fix / maintain :occasion5:
- Große
watch this... it's totally related ( must watch it all )AMG wrote:part of the fun in owning a classic - always a never-ending source of new things to fix / maintain :occasion5:
https://www.youtube.com/watch?v=0ZvBwqemoLg
- C Class
Haha, great video
