AM RADIO CRACKLING
Warren Wilson
Model you own: w210
AM RADIO CRACKLING
Post by Warren Wilson » Fri 17 Jun, 2011 12:29 am
A loud crackling sound from the speakers when the engine is running and the radio is on the AM band. The cracking 'tempo' increases when the engine revs increase. Sounds like some type of ignition problem. CD player and FM unaffected - only the AM radio band. Perhaps a trip to an auto elecrtician is easiest, however I never do things the easy way. Appreciate any comments.
Thanks in anticipation
Warren Wilson
1999 E240
:boohoo:
Warren
2008 W204 C280 Avantgarde
http://www.imageupphotography.com
FaceBook: This Fascinating World
I'm so proud of my Benz, I would refuse a jump start from anything other than another Benz.
Re: AM RADIO CRACKLING
Post by AMG » Fri 17 Jun, 2011 12:47 am
sounds like you have a ground loop. changing /adding the suppression capacitor on your alternator and isolating any ground loops should resolve your issue. check any rca cables running near power are isolated.
best place to start is by cleaning all the earth connections from your radio, battery, alternator, starter, main engine earth strap etc. making sure they are secure and clean. make sure all the earth connections to the radio ground at the same point. swap the alternators suppression capacitor for a new one. after that you get into the wiring harness and look for ground loops created by non-factory wiring.
Warren Wilson
Model you own: w210
Post by Warren Wilson » Fri 17 Jun, 2011 4:03 pm
JoeB
Thank you for your comments - much appreciated.
Warren Wilson
Warren
Post by Tony From West Oz » Fri 17 Jun, 2011 10:22 pm
This can also be caused by low RF level to the receiver, so also check the antenna (does it go all the way up?) and antenna cable to the radio.
Is this present when in the city or only in remote areas?
