Stuck Stackers(Alpine 6 Disc)
shockvalue
Model you own: w209
Post by shockvalue » Tue 04 Jan, 2011 7:06 pm
My Alpine 6 CD stacker intermittently gets stuck and will not eject(CLK320). Not all that unusual it seems from reading various fora.
I accidently discovered this procedure which generally works for me:
First make sure the Command unit is on,
Then press the Eject button on the CD unit,
Then while the button is flashing turn off the Command unit.
The Cartridge usually will then eject - sometimes you have to repeat the procedure.
I'd be interested to hear if this works for others with this problem.
