Toyota landcruiser with merc Diesel conversion
Post by Mercmad » Sun 29 May, 2016 8:39 pm
This is quite a common thing to do in the US, repower a cruiser with a OM 617 Normally but this guy has gone with a OM 606 ,the DOHC 4 valve engine which they have modified with a mechanical pump instead of common rail injection. No ECu etc.
http://forum.ih8mud.com/threads/the-mer ... 06.767948/
Re: Toyota landcruiser with merc Diesel conversion
Post by Tony From West Oz » Sun 29 May, 2016 9:39 pm
Mercmad wrote:This is quite a common thing to do in the US, repower a cruiser with a OM 617 Normally but this guy has gone with a OM 606 ,the DOHC 4 valve engine which they have modified with a mechanical pump instead of common rail injection. No ECu etc.
Mercmad,
None of the OM60x engines were common rail. The reason for using the IP from an OM603 was to overcome the lack of an ECU in the Tojo, which the IP from the OM606 needed to allow the 'fly by wire' of the OM606.
In the USA, OM603 were available with a turbo, but not in Oz. This the OM603 IP gave then the ALDA and mechanical throttle.
Thanks for the link.
Post by AMG » Mon 30 May, 2016 2:33 pm
There's a lot of stuff said about the 603 pump on the 606a, but the 606a's pump is actually a better unit, the downside is that people like the 'all-mechanical' and no electrics in their diesel engine bays.
Currently looking at 606a's and 722.6 from places like Serbia where you can get good used ones for about a grand.
Post by Tony From West Oz » Tue 31 May, 2016 12:35 am
AMG wrote:There's a lot of stuff said about the 603 pump on the 606a, but the 606a's pump is actually a better unit, the downside is that people like the 'all-mechanical' and no electrics in their diesel engine bays.
The other thing is that people don't want the Mercedes ECU. Is there a compatible ECU from another source which will work on the OM606?
Ditto for the OM605
tsharkey
Post by tsharkey » Wed 01 Jun, 2016 6:00 pm
Tony From West Oz wrote: The other thing is that people don't want the Mercedes ECU. Is there a compatible ECU from another source which will work on the OM606?
Ditto for the OM605
I am spec'ing up an OM605 and have bought the IP from a Turbo OM602 (US) as I couldn't find an after market ECU to deal with the IP and was advised the Benz Unit requires ABS sensor data and other inputs to operate effectively (Very happy to be corrected). I have also had to repair the electronic IP on my W202 OM605 because of some common idle arm not returning properly fault so am not so keen on them. The 722.6xx has an aftermarket ECU as plenty of Chrysler folks have modded them.
You can get OM605 722.6xx combos form the UK for a grand. Its bringing the engine into Oz that costs.
Post by AMG » Wed 01 Jun, 2016 8:41 pm
Tony,
There is a standalone ECU available for the 606a, I'll send you the link when I dig it out of my stuff here...
Edit: https://controls.is/dsl1.html
tsharkey
Post by tsharkey » Fri 03 Jun, 2016 5:37 pm
AMG wrote:Tony,
Very informative - Thanks ... Costs about the same as a good turbo mechanical IP.
Return to “The MOD Squad”
