W204 Steering Question
nicholas128
Post by nicholas128 » Sat 28 Apr, 2018 11:37 pm
Does the W204 have steer-by-wire or is it a hydraulic system?
Re: W204 Steering Question
Post by John Green » Sun 29 Apr, 2018 9:55 am
Its a fairly standard system with a Hydraulic pump and steering rack, I think it is a speed sensitive system (lighter at parking speeds) so there is some electrical input, but the steering wheel is mechanically connected to the front wheels/tyres.
nicholas128
Post by nicholas128 » Sun 29 Apr, 2018 6:08 pm
Thanks John.
Post by AMG » Sun 29 Apr, 2018 6:40 pm
If your vehicle has code 213 then there is a proportioning valve on the steering rack which is the speed sensitive input. It is electronically controlled. The power steering system is hydraulic.
w205 -> has electric assisted speed sensitive steering.
