W202 OBD II code reader
johna
Post by johna » Wed 14 Feb, 2018 8:59 am
Hi all.
I've done a search of this forum and couldn't find a conclusive answer for Australian models.
I have a 2000 model C200T (W202).
Will one of the cheap eBay OBD2 code readers work on this model? Does it have the standard port I do I need an adaptor of some sort? And where is the port?
If these code readers don't work, does the LED method I have read about work on Australian models?
Thank you.
W202 2000 C200T Elegance
Re: W202 OBD II code reader
Post by Ivanerrol » Wed 14 Feb, 2018 11:24 am
No OBD II on Australian cars until the W203 and W211.
Cheap OBD scanners will not work at all.
Post 1997 Oz Benz cars used OBD and a half. For full diagnosis you need Star or equivalent iCarsoft knockoff.
If you want to cancel fault codes such as SRS or reset limp home mode a Independent specialist may have something.
There are some generic sub $1,000.00 units which will read codes however as I have seen these codes need a Mercedes expert to diagnose them accurately.
I know of a man with a a '98 C200 who spent a small fortune taking his car to a "European car Specialist" who misdiagnosed code issues with a generic scanner.
LED is very limited.
There's a 32 port round connector under the bonnet.
johna
Post by johna » Tue 20 Feb, 2018 9:45 am
Thank you very much for the information. It's good to have a definitive answer.
