Drivers door electric issues
Post by Tony From West Oz » Wed 31 May, 2017 2:36 am
My Drivers door window and RV mirror stopped working. The CL is not affected.
This all happened at the same time and all other doors work correctly.
Any ideas where to start?
I am reluctant to remove the door card as the clips are likely to disintegrate when removed.
Re: Drivers door electric issues
Post by T-Modell » Wed 31 May, 2017 2:57 am
Hi Tony,
first the fuse incl. their contacts (rust?). Then check the switches (cables, contacts). If all that is ok ... well then I guess you have to remove the door panels to see the wires/connectors/motor etc.
If you remove the switches, try to connect another switch to this door ... the old joke "What does a Siemens Technician do, when he has a flat tyre? ... He swaps it to the other side and checks if the fault moves with it" ... :laughing6:
Post by Ivanerrol » Wed 31 May, 2017 1:23 pm
For a few bucks on ebay, you can buy a kit that contain door card removal tools there are also kits that contain both audio and door card removal tools.
like these : http://www.ebay.com.au/itm/4-X-Pry-Kits ... Sww9xZCZl5
or this : http://www.ebay.com.au/itm/Car-Door-Pan ... SwcUBYUL4f
Post by Tony From West Oz » Wed 31 May, 2017 10:27 pm
Post by Tony From West Oz » Fri 18 Aug, 2017 10:01 pm
Fuse replaced by mechanic during GP work fixed the problem
