Cruise control not working C180 W202
Dlawrence103
Post by Dlawrence103 » Sat 11 Feb, 2017 8:44 am
Hi
Just bought a 1997 C180 W202
My cruise control is not working, does anyone know where the control module is located
I can't find it
Also the centre brake light is not working, I read somewhere this could cause the cruise to stop working? Is this true?
Dave
Dave Lawrence
Current drives
2004 Landcruiser V8
1997 C180
Past Drives
3 x Landrover Defenders
BMW 735i
Golf GTI MK1
VW Corrado
306 GTI
106 GTI
300zx TT
Celica GT4
Leon Curpra R
Re: Cruise control not working
Post by Ivanerrol » Sat 11 Feb, 2017 5:09 pm
Not only do the brake lights must be all working, but the bulbs must be the specific wattage.
Your cruise control location.
Open your bonnett.
see the arrow pointing to the plastic cover (if you have one) - remove this cover.
Your cruise amp is the box arrowed. In your car you will have two boxes mounted in that location. The CC AMP is the smaller rectangular of the two.
By the W202 MB had achieved much better reliability with the cruise control. The throttle is electronically controlled.
Dlawrence103
Post by Dlawrence103 » Sat 11 Feb, 2017 9:47 pm
Thanks IvanErrol,
My third brake light is currently not working and I've ordered a replacement bulb, so hopefully that could fix it.
Under my bonnet looks a bit different from your pictures, and inside the electrical box is a row of fuses and a relay, then 1 long computer in the middle with 2 big plugs attached, then 1 computer at the aft end of the box, which has ABS written on it.
I'm Not sure which one is the cruise control unit.
I'm struggling to attach a picture as the pictures my iPhone takes are to big
Dave Lawrence
Current drives
2004 Landcruiser V8
1997 C180
Past Drives
BMW 735i
Golf GTI MK1
VW Corrado
306 GTI
106 GTI
300zx TT
Celica GT4
Leon Curpra R
Dlawrence103
Post by Dlawrence103 » Mon 13 Feb, 2017 8:31 pm
i found an old camera that would take smaller pictures so I can attach them to the posts :dance:
So I was wondering which box was the cruise control computer, or if it was part of the computer at the aft end of the box, which says ABS on it??
cheers
Dave
Dave Lawrence
Current drives
2004 Landcruiser V8
1997 C180
Past Drives
BMW 735i
Golf GTI MK1
VW Corrado
306 GTI
106 GTI
300zx TT
Celica GT4
Leon Curpra R
Dlawrence103
Re: Cruise control not working C180 W202
Post by Dlawrence103 » Sun 05 Mar, 2017 1:28 am
Ok, so I have replaced the 3rd brake light with the correct bulb and the cruise control still doesn't work.
Any ideas where the cruise control computer module is located?
Dave Lawrence
Current drives
2004 Landcruiser V8
1997 C180
Past Drives
BMW 735i
Golf GTI MK1
VW Corrado
306 GTI
106 GTI
300zx TT
Celica GT4
Leon Curpra R
Post by Ivanerrol » Mon 06 Mar, 2017 9:54 am
Sorry about that.
Your car is a later model and cruise is 100% computer controlled.
You will need a diagnostic scan to find your issue.
